J5 Telecaster Pots... 250k?
Started by danger5oh, August 04, 2011, 07:34:32 AM
danger5oh
I just picked up a new J5 Telecaster and within minutes of bringing it home, I had it in pieces ready to start the usual modification process that all of my guitars go through.  First order of business was to change the bridge pickup from the Fender Enforcer Humbucker to a BKP Aftermath.  Now, I've heard great things about the Enforcer, and it sounded pretty good during the 15 mins that I played it at home, but it seemed a little too tame for my tastes.  Enter BKP Aftermath...
Now, after pulling the control plate off I notice something unusual... at least for me.  This guitar has 2 pots... a neck p'up volume and a bridge p'up volume... and BOTH of them were 250k pots!  The neck p'up is a single coil Twisted Tele and the bridge p'up was an Enforcer humbucker.  I'm used to seeing 500k pots in most of my guitars with humbuckers and 250k pots in Strats with single coils, but I've never seen a Humbucker with a 250k volume pot.
Could this be the reason I wasn't too thrilled with the sound of the Enforcer pickup?  And should I go ahead and wire in a BKP 550k CTS pot while I have everything taken apart?  Or would the BKP Aftermath sound good with the 250k pot... as maybe Fender's thinking was that this guitar would sound too bright with a 500k pot?  And can I mix and match a 250k pot and 550k pot on the same guitar?
Any help would be greatly appreciated...
Washburn X-81 Face Eraser w/ BKP Warpig set
I have all 500k pots in an HSS-strat with autocoilsplit. Works fine. But, you'd better ask BKP what to use. They're experienced. Btw a lot of forummembers know way more about this stuff then I do.
Transcend
I would first try the 550k pot with the stock pickups im pretty sure it will get rid of the tameness you experienced.
That isn't saying you'll like it over the BKP but its definitely worth a shot.
I find that humbuckers with anything lower than 500k sound castrated and boxy
BigB
As far as I'm concerned, stock gibbies 300K pots just dont cut it even with low-output vintage voiced 'buckes, so let's not talk about 250K pots for a modern hot one. I definitly agree with Toe-knee: replace it with a 500K and eventually give the stock bucker another try.
wrt/ mix & match, since you have per-pickup volume pots, this is no problem.
