Help with Vintage30 spec for cab
Started by witeter, August 09, 2011, 10:47:17 AM
witeter
hey guys i currently have a marshall 1960a 4x12 cab with G12t75's in it. Im hoping to install 2 celestion vintage 30s in an xpattern. Which celestion V30's do i need? 16ohm?  is it a particular size? im new to this kinda stuff so any help would be great.
[url="http://www.facebook.com/flailhead"]http://www.facebook.com/flailhead[/url]
[url="http://www.facebook.com/insunaband"]http://www.facebook.com/insunaband[/url]
[url="http://www.sabreguitars.co.uk"]http://www.sabreguitars.co.uk[/url]
Sabre Custom Wraith
Ibanez RGA42
pretty sure they are 16ohm in those cabs.. someone will confirm i'm sure. if not - whip the back off and have a look at the speakers in there.
If it has 4/16 mono switching and 8ohm per side stereo options, then they will be 16ohms.
witeter
Yeha at the back it has 4ohm or 16ohm options, so i assume that would make it 16ohm speakers-this may sound stupid but do 16ohm speakers come in a standard size? or can they vary?
Sabre Custom Wraith
Ibanez RGA42
Quote from: witeter on August 09, 2011, 11:26:38 AM
there are many different sizes.. but 4x12 means it has four 12" speakers, so you need a 12" speaker, which the vintage 30 usually is! :)
witeter
awesome so 12" 16ohm vintage 30-great :-)
installing 2 new speakers is it something i shd get a tech to do or is it easy enough to do myself?
Sabre Custom Wraith
Ibanez RGA42
Quote from: witeter on August 09, 2011, 12:01:30 PM
can you solder? if so its a really easy job.
witeter
havent done soldering since school but i can learn :-) good to hear its easy though-thanks
Sabre Custom Wraith
Ibanez RGA42
Quote from: witeter on August 09, 2011, 12:08:19 PM
it depends on the cab. some speakers are soldered in there, and some just have push-on tags so you don't need to solder at all - just swap over the wires.
open her up and have a look inside.
witeter
cool! no soldering would be even better! cheers man will do
Sabre Custom Wraith
Ibanez RGA42
