Author Topic: What brand of 6L6 tubes do you like an why?  (Read 14119 times)
Transcend
Re: What brand of 6L6 tubes do you like an why?
« Reply #15 on: August 11, 2011, 07:12:54 PM »
For high gain stuff where all the sound-shaping comes from the pre-amp the output tubes have neglible influence on tone unless your amp is totally dimed (including the master volume).
It's more important that the tubes are reliable.
I think this is one of the biggest myths out there - you will definitely notice a difference in punch with good valves versus cr@p ones.
+1
I'm sure people think this because it's written on the Soldano website, but you'll notice a difference even at low volume between something like an EL34 and a 6550 for example.
Even the same valve type from different manufacturers can give a considerable boost/drop in tone
« Reply #16 on: August 11, 2011, 07:48:59 PM »
+1
I agree with both you guys, maybe we should do a mythbusters FAQ on amps  :lol:
« Reply #17 on: August 11, 2011, 08:51:48 PM »
I have found that in modern amps power valves do change the sound and quite drastically.
I have noticed huge differences between
JJ (good and reliable)
EH (shrill in the highs and generally makes amps sound thin)
=C= excellent in every aspect but double the price of most other valves
For this reason I swapped my EH 6V6's (not 6L6's) got JJ's. I gig every weekend once or twice. Never a problem.  :)
timski
« Reply #18 on: August 12, 2011, 10:05:10 AM »
Well, FWIW after my previous controversial comment, in my '73 Vibrolux Reverb I use JAN Philips 6L6WGB which are basically a 5881 so you get a bit less headroom than with the usual 6L6GC.
My current set has lasted 5years, and I usually play the amp at break-up point where I know the power valves are being properly pushed.
« Reply #19 on: August 12, 2011, 12:59:47 PM »
I remember when you could get those valves for £11.00 each - great valves, love them.
timski
« Reply #20 on: August 12, 2011, 03:36:20 PM »
You don't look that old...
« Reply #21 on: August 12, 2011, 04:01:37 PM »
cheers, £5.00 in the mail to Timski  :lol:
asianaxeman
  • It's all about the Thrash!
« Reply #22 on: August 12, 2011, 07:32:49 PM »
EHX are my fave, warmer, less shril and harsh than JJs - but never found them to be thin.
d1dsj
« Reply #23 on: August 13, 2011, 11:16:12 AM »
Another vote for the JAN Philips here.
