Author Topic: Pick up advise for a BC Rich  (Read 2039 times)
Dr.Pain
« on: August 11, 2011, 02:24:42 PM »
I have a Warbeast 1 which was an unexpected buy a while ago mainly due to how nice the unfinished neck feels.  It's a basswood body, maple bolt on neck and rosewood fret board.  I keep this tuned in E as I mainly use to play Iron Maiden, '80's Metallica, '80's Kreator and AC/DC  I'm after a pup that will sound nice, clean across the range of distortion that's typical of the '80, for the bands mentioned, and works well for the dirty channel AC/DC stuff.
My 7string with a c-pig is great for real heavy stuff but not so great for this.  A bit too heavy.  I have an ESP too that came with EMG-ESP pups from 2007 or so.  That works quite well but got that tuned down to D.  Need to give the Warbeast a job and make it sound better.
Any ideas? :)
Re: Pick up advise for a BC Rich
« Reply #1 on: August 11, 2011, 03:02:41 PM »
Hi,
You set a wide range of tones to be covered by just one pickup.
80s Metallica, 80s Kreator and Iron Maiden = Cold Sweat or Nailbomb, eventually Miracle Man, with Cold Sweat being my first choice.
AC/DC = Riff Raff. With a lower gain setting on the amp the Cold Sweat should do that as well.
Dr.Pain
« Reply #2 on: August 11, 2011, 03:44:19 PM »
It is a wide range but if I can find something that works over that tone, doesn't have to be spot on that exact sound, then I'll be pleased.  Had a listen to cold sweat and got an email reply saying cold sweat as well so that might be the go in time.
Nolly
  • Global Moderator
« Reply #3 on: August 11, 2011, 05:18:31 PM »
Yep, the Cold Sweat would do the majority, though I think you'd find the Nailbomb would cover the AC/DC side of things with more conviction
« Reply #4 on: August 11, 2011, 08:32:10 PM »
How would the Holy Diver do in basswood?
Nolly
  • Global Moderator
« Reply #5 on: August 12, 2011, 11:07:49 PM »
The Holy Diver is a great match in basswood instruments, though I think the Nailbomb or Cold Sweat would be more appropriate here
