Recommendations
Started by keith, August 11, 2011, 07:33:55 PM
keith
Now then all looking for decent boost pedal to use with my Orange Dual Terror so I can run tiny channel for clean fat channel for rivvum and lead just need that something to knock it up that extra notch for solos  ideas please
cheears
Orange Dual Terror Head
Zilla 2x12 cab
dynacomp - thats what I use for solos.
Klon(e) would get my vote!
Quote from: Twinfan on August 11, 2011, 08:13:27 PM
They're superb. I would also look at the Brunetti Taxidrive, not cheap, but not a Klon-price either.
Crunch
If the gain is set low enough, the Seymour Duncan SFX-01 Pickup Booster is quite phenomenal.
The SFX-03 Twin Tube Classic would be more versatile, as it works amazingly with low and high gain- without colouring the tone, too much.
I've always liked using EQ pedals to push the needed frequencies forward. There are some great tube pedals from Electro-Harmonix that feature a 3-band EQ. If you need more tweakability, the MXR KFK-1 has been discontinued, but it was amazing. The M108 is the next best shot, for the money.
Praise the Sunn.
marauder
Sancho
I use a Maxon OD9, which is basically a Tubescreamer.
Love it, but it does color your tone. The MXR Zakk Wylde overdrive is pretty good as well and a bit more transparent.
For a simple clean boost, you could do worse than get the MXR Microamp.
Hey Nonny Nonny mylord!
theres been some good suggestions here. i chop and change depending on my mood at the guitar in question - thunder tomate treble booster, OD-1 and modded GE-7 are favourites this end
i'm tempted to suggest some sort of EQ pedal. it will give you that boost, and a nice range of control. its hard to try out these boxes in a shop and then you get them home and they work differently in your rig. i've always been able to tweak the settings on an EQ pedal and use it as a good booster whatever the situation.
shobet
If you're after just a boost then the Xotic EP booster is a great little pedal. If you want a little hair added then a Nick Greer Ghetto Stomp, Skreddy Screwdriver or a Fulltone OCD are worth a looksy.
My 6p worth.
timski
My No.1 recommendation for a non-TS type pedal:
http://gundrymedia.typepad.com/throbak_electronics/2006/11/overdrive_boost.html
Does everything from totally transparent clean boost to full-on fuzz with very effective EQ knobs that take you from midbump to mid-scoop.
The most recent version also has a footswitchable 'pre-gain' control for effectively 2 different levels of boost.
Not cheap, but not as costly as some of the others mentioned here.
[url="//www.myspace.com/timrobrus"]www.myspace.com/timrobrus[/url]
the EQ pedal idea is a good one - I use one in my rig to tweak the mids, so its on all the time.
