Author Topic: Bare Knuckle Bridge and Seymour duncan neck or ?  (Read 2143 times)
professeur
« on: September 05, 2011, 10:14:06 PM »
I have a set of seymour duncan SH6 bridge and SH4 neck on my guitar. I am changing the bridge with a Miracle Man  :P but will keep the SH4 Neck pickup because of its tonality.
Do I need to change the pots or capacitors value at all? Is there any adjustment that I need to make to the components?
It is a 5 way lever switch. 1 tone 1 volume.
Or can anyone suggest a BK neck pickup which will match the SH4 type of tone?
« Last Edit: September 06, 2011, 09:15:00 AM by professeur »
Transcend
Re: Bare Knuckle Bridge and Seymour duncan neck
« Reply #1 on: September 05, 2011, 10:23:11 PM »
nope you dont need to change anything other than the bridge pickup everything else will function fine with it and the duncan
Re: Bare Knuckle Bridge and Seymour duncan neck or ?
« Reply #2 on: September 06, 2011, 10:59:55 PM »
get a calibrated set  :D
professeur
« Reply #3 on: September 07, 2011, 11:08:41 AM »
I already installed the Miracle Man..Awesome pickup! A bit late to get a calibrated set. but the Seymour Duncan SH4 does not sound as if it matches the tone of the MM. I have a mahogany Ibanez.
I mainly play Iron Maiden, Machine Head, In Flames type of music.
Any suggestion of a neck pickup (I know u cannot have it all in one neck pup)
« Reply #4 on: September 07, 2011, 03:10:24 PM »
buy a miracle man neck and you'll have a calibrated set
