I guess I should share some specs for the two axes too
Hardtail S type - by customer request and sold!
Alder Body
No - neck plate - carved heel but not quite the full rounded version as we often do as neck was originally done to be completely stock before we used it on his project
Maple neck with rosewood fingerboard
25.5" scale with Dunlop 6155 frets (9.5" radius board)
Sperzel machineheads
Earvana shelf nut for improved intonation
Hipshot hardtail bridge - through body stringing
Dunlop strap locks
Pickguard is loaded with BKP Irish Tour pickups
CRL5 way switch and switchcraft jack
Pots are BKP/CTS 280k with a BKP/Jensen 0.022uF cap on the tone control
Supplied with Hiscox case
Tabby Hybrid - made for stock and available at £1799
Alder Body
No - neck plate - all access carved heel
Fender modern 2 point tremolo (we liked it and had one in stock so we thought - why not use it)
Dunlop strap locks
Pickguard is loaded with BKP pickups:
Bridge pickup is BKP Boss
Middle and neck pickups are BKP Mothers Milk
Pots are BKP/CTS 280k with a Vitamin Q 0.022uF cap on the tone control
Push pull pot on 2nd tone control allows mixing of bridge and neck pickups in all positions other than position 3
