Author Topic: Damaged neck :-(  (Read 2664 times)
plastercaster
Damaged neck :-(
« on: September 09, 2011, 07:16:26 PM »
Hello all,
I'm posting on behalf of a friend who owns an old Gordon smith GS1 (LP junior style)
Unfortunately it was dropped (from a strap I lent her :-S) and now there's a crack in the paint across point where neck meets headstock (in classic les paul style \/ ).
(this is an image of a more serious break to show the location)
The headstock is still attached but tuning stability has disappeared. Can anything be done about it?
How much would it cost to repair?
Many thanks!
PS feel free to move to tech if this is misplaced.
« Last Edit: September 09, 2011, 07:19:02 PM by plastercaster »
Orange rocker 30
VHII and Mississippi queen
Re: Damaged neck :-(
« Reply #1 on: September 09, 2011, 08:49:14 PM »
If the tuning stability's gone it sounds like it's more than just a crack in the paint.
If it's a clean break I understand it's an easy repair - although I wouldn't try it myself.  :wink:   People always say a repair of this type is as strong or stronger than the unbroken neck, but I'm not sure I've ever believed it.....
No doubt Jonathan or Wez will give proper advice.  :)
Shag101
« Reply #2 on: September 09, 2011, 08:54:17 PM »
dont have any insight on how to repair, but this is exactly the reason i have strap locks on all my guitars..
definitely sux.... :cry:
Warpig = '88 Charvel Model 1
« Reply #3 on: September 09, 2011, 09:34:31 PM »
I see you have a Feline Custom, surely there's no one better to call? :P
« Reply #4 on: September 09, 2011, 11:26:40 PM »
the one in the pic is a relatively easy repair
it would be hard to say about the GS without seeing it - all breaks are a bit different
plastercaster
« Reply #5 on: September 11, 2011, 10:19:42 PM »
I'll get some proper pics and get on to Jon about it then!
Orange rocker 30
« Reply #6 on: September 12, 2011, 01:32:39 AM »
Cool - pix will help
the Sg break you showed would be a fairly straightforward fix
The GS may be slightly different so best to see pix
Zaned
« Reply #7 on: September 13, 2011, 07:22:01 PM »
Glue is stronger than wood, so it won't break from the same place again (unless done badly).
For the topic starter: don't worry, It'll most probably be a player again :)
-Zaned
Paths are for followers.
