Looking for a "true 80s" H/S/S-set for a Strat
Started by Tero, September 14, 2011, 08:15:42 PM
Tero
Hello everyone!
I'd like to keep this as simple and short as possible. I hope I don't get too excited... I tend to run with scissors around this subject :)
I have a basic Strat (with alder body, maple neck, rosewood fretboard, 6-screw vintage tremolo etc.) and I'd like to turn it to a Swiss armyknife of 80s pop/rock and "modern pop". I have been looking for noiseless pickups, but I don't want those singlecoils to be stacked humbuckers. I was looking for EMG's S/SA/etc. active pickups, but then again... I have always been against active pickups and batteries in guitars.
I still like the compressed and chorused Strat-sound of the 80s that can be heard on countless records... from Chris Rea to Bananarama, and from The Chameleons and Roxy Music to Duran Duran. Even for today's Laura Pausini and other GOOD (at least in my opinion) modern pop music.
So... is there any good BKP-choices around for the Strat singlecoils and bridge-position humbucker? I like to use a lot those 2nd and 4th positions of a pickup switch too.
Here are some sound samples of the desired:
Roxy Music - http://www.youtube.com/watch?v=p9PAuWV-Vn0
The Chameleons - http://www.youtube.com/watch?v=MC70Cl0x2Q8&feature=player_detailpage#t=30s
Duran Duran - http://www.youtube.com/watch?v=gudEttJlw3s
Chris Rea - http://www.youtube.com/watch?v=1EBw_da7BZk
I use mainly 2-3 amps. Main amp is fairly modern sounding Hughes&Kettner Trilogy head, second one is Dr. Z Z-28 head and I also have couple of tweed-style Fender-clones (f.ex. Cornell Romany Plus, Ted Weber's 5F1 DIY-kits etc.)
I also have 3 sets of BKP singlecoils already on three other Strats (The Apache on '54 replica Strat, Tim's custom '62-set on '62 replica Strat and Mother's Milk set on EJ Strat). Mother's Milk set actually sounds pretty good for 80s stuff too, but there's something I'd like to change on it. Don't know what exactly... something tonal changes maybe. Apache is way too vintage for 80s stuff. Actually that custom '62 works pretty well... it lacks some power and bottom but boosted with an OD or EQ-pedal it works rather well.
Also, those singlecoils I'm gonna get, should fit with BKP's humbucker in bridge position.
Any ideas how to approach this subject and how to "eliminate" the plethora of choices? I'm also willing to hear some recommendations for noiseless singlecoils as long as they are NOT stacked hum-buckers.
Thanks already and have a good one. Cheers!
Crazy for BKP... almost 30 pickups and still ordering more :)
I would go for a VH2 and a pair of Mothers milk myself (or maybe Black Dog)
VH2 is vintage enough but with the ability to rock out in a totally 80s fashion
These days there is more than enough gain available with most amps , so a hot pickup isnt what is needed
Getting a good clean tone is more tricky
I like the VH2 as I feel it has a little more top and bottom than many humbuckers - but not lacking in mids either and that helps with cleans sounding good.
I'm with you on Mothers milk - I think it'll be the closest choice for a lot of that silky 80s strat tone
I like the Pat Pending pickups too - I just feel the MM has a little more low end
You may find using an external compressor helps though
EMG SAs have that compression  and to many people epitomise that 80s sound, but passives can do it - maybe just benefit from a helping hand
I have two HSS-sets:
1: MXG customstrat swampash/ebony freatboard: Crawler/IT's. Great allround set and the Crawler has the dc-resistance for a balanced split with the middle-IT.
2. Fender American Series Ash-strat: VHII and Mothers Milk with autosplit on the fourth pos (one coil of the hb/middle-sc). The MM's are a brighter and have less bass then the IT's. I like the MM's though for Frusciante-sounds. The sec. position is happening too. The VHII splits well, but this position is a little dominated by the middle-MM, since the VHII has only 9k. Nevertheless a usable sound, perhaps a bit darker then in a trad. strat. The VHII is great in a alder or ash bolt-on guitar. The offset coils provide a great rocksound when pushed. The VHII is very articulate and sensitive for pick attack. When you dig in overtones jump out. Cleans up great, with a belllike sc-vocal quality.
For what you're after the Crawler could be a good allround humbucker. It beefs up the tone in alder and the topend is rounded, but bright enough when you find the sweet spot in the height. It has still  PAF-character, but with more compression which is nice for soloing. An alternative could be the Abraxas, which has bit more chime in the topend, but still beef in the mids. Splits (14k) great too. A VHII wouldn't make a bad impression either, although the fourth position will be dominated by the middle pu.
For the singlecoils I would look at IT's, they have a bit more weight then the MM's, but when you roll the vol.knob a tad back, they can produce early sixties-tones too. But maybe even Sultans would fit the bill. They have a mellower, hollower character that could be right for the tones you're after. Certainly for Chris Rea-stuff.
Tero
Quote from: FELINEGUITARS on September 14, 2011, 10:21:41 PM
Yeah... VHII has been on my list too. I have one of those as a neck pickup on ESP Horizon FR-II that is neckthru with alder wing body. Paired with Miracle Man bridge pickup. I could try that one out for sure for H/S/S bridge position.
QuoteI'm with you on Mothers milk - I think it'll be the closest choice for a lot of that silky 80s strat tone
I definitely love Mothers Milk and PAT.Pend.-series singlecoils, especially in my regular strats. Just like you said... it's tricky to keep things clean and tidy and way easier to add gain. That's something I have been consciously doing for the last 5 years. I used to have über-hot pickups earlier but now my absolute favorite set is BKP Stormy Monday and The Mule on Les Paul Standard :)
I also have couple of "legendary" compressors on my pedalboards (Ross grey box clone, Keeley 2-knob and MXR's original Script Dyna Comp).
I guess my "searching" is more about looking for differences. I don't want to have another '54 or '62 replica Strat but something completely different. Still I wouldn't want to have active pups eventhou that would be "the 80s again".
Quote from: Telerocker on September 14, 2011, 11:30:10 PM
That sounds pretty good. The bridge humbucker should be well-splittable since I dig to use those "in-between" tones. I'm definitely going to write down that Crawler as one of the choices for bridge pu.
Quote2. Fender American Series Ash-strat: VHII and Mothers Milk with autosplit on the fourth pos (one coil of the hb/middle-sc). The MM's are a brighter and have less bass then the IT's. I like the MM's though for Frusciante-sounds. The sec. position is happening too. The VHII splits well, but this position is a little dominated by the middle-MM, since the VHII has only 9k. Nevertheless a usable sound, perhaps a bit darker then in a trad. strat. The VHII is great in a alder or ash bolt-on guitar. The offset coils provide a great rocksound when pushed. The VHII is very articulate and sensitive for pick attack. When you dig in overtones jump out. Cleans up great, with a belllike sc-vocal quality.
I agree. That was one of the main reasons why I bought VHII for my ESP's neck position. Also, Frusciante and RHCP was the reason why I've got MM's for Fender EJ Strat on a first place. Maybe I could (or should) ask Tim if he could "underwound" IT's to match up with VHII or slightly overwound MM's with Crawler? :)
QuoteFor what you're after the Crawler could be a good allround humbucker. It beefs up the tone in alder and the topend is rounded, but bright enough when you find the sweet spot in the height. It has still  PAF-character, but with more compression which is nice for soloing. An alternative could be the Abraxas, which has bit more chime in the topend, but still beef in the mids. Splits (14k) great too. A VHII wouldn't make a bad impression either, although the fourth position will be dominated by the middle pu.
It probably isn't a bad thing if the VHII is slightly dominated. It kinda makes the sound more original and less humbucker-y. Like I said, my quest could be easily filed under out-of-the-box type of thinking. At least when considering today's ideal sounds. 80s were just as freaky as the hair-dos and clothing :)
QuoteFor the singlecoils I would look at IT's, they have a bit more weight then the MM's, but when you roll the vol.knob a tad back, they can produce early sixties-tones too. But maybe even Sultans would fit the bill. They have a mellower, hollower character that could be right for the tones you're after. Certainly for Chris Rea-stuff.
Have you fiddled with tone caps and IT's? If so, what kinda results you've got? VHII & Sultans could be one way to go for sure. Thanks for pointing those out. I have always managed to forget 'em... don't know why.
Thanks to both of you. I think I'll ditch those actives (not even consider them) for the good. Never liked 'em and not going to start any day soon. Mr. Mills should have some "instant 80s" Strat-set ready for lunatics like me :)
-Tero
BigB
Quote from: Tero on September 15, 2011, 12:13:30 PM
The Crawlers is known to work fine splitted (I still have to rewire all the switches on my Vox to try it out :lol:).
This is in "auto-split" mode, so it isn't supposed to sound "humbucker-y" ;)
Tero
Quote from: BigB on September 15, 2011, 12:43:07 PM
I think it's pretty clear that Geoff's Crawler it is... since I'm gonna need well-splitting bridge pu for sure!
Thanks for confirmation.
Quote
Noted... but with middle pu and splitted bridge pu together we are talking about two coils on, right? Now the splitted bridge humbucker with a weaker coil (in VHII that is) + middle pu would make even less humbucker-y sound... therefore those quotation marks. Maybe I should have said "not the most usual sound" because that would make better sense.
I guess I'll skip the VHII for now and go with the Crawler (bridge position) and two MM's or Sultans. The 80s, here I come! :)
I don't have any useful suggestions to make, just wanted to say it's quite refreshing to see someone on this forum wanting pickups for '80s pop sounds!
Good luck in your quest!  :D
BigB
Quote from: Tero on September 15, 2011, 01:29:28 PM
And how does this differ from  a SC middle pup and a SC bridge pup ? We're still talking about two coils on, right ? ;)
Just had a thought about this.... as we know, the VHII has one coil wound hotter than the other.  I don't know how big the "offset" is, but I believe it's more than most of the other BKP humbuckers.
I assume it's the hotter coil which is active in split mode, but maybe not....?  :?
Quote from: BigB on September 15, 2011, 06:05:28 PM
I meant in my Fender the fourth position automatically switches to one coil of the  VHII and middle-MM when I use the fiveway-switch.
On my MXG I have an extra option: Crawler full HB + middle-IT or (when the toneknob is pulled), one coil of the Crawler and middle-IT.
I would say the splitted Crawler with IT is brighter then the VHII/MM split, due to the fact that the coil of the Crawler brings in more output and therefore more highend. Nevertheless the VHII/MM is very usuable. Yes Philly. I think it's the hotter coil, but I'm not 100% sure. Big B, the fourth position (autosplit) is very clean Fenderish.
I would not ask Tim to overwound an MM or underwound an IT. The IT to my ears is an overwound MM with a bit more bass and midrange. Just roll the vol.knob a tad back and your in MM-terrority.
Tero
Quote from: Philly Q on September 15, 2011, 01:51:25 PM
Thanks... and glad to hear :)
I used to play metal in few different bands (and few different metal styles/sub-genres). I used to have hot(test) pickups and loads of gain, and not a single guitar with singlecoils. Well... nothing wrong with that either but these days I find myself listening to and playing to many different styles. Mainly those über-cheesy 80s pop and rock songs, but also italo pop, some James Brown-ish funk tracks etc. That's also the reason why I'm on this quest to find something new and different from what I have in rack already. I actually started using BKPs some years ago with a Nailbomb :)
Alright. I'll keep that in mind. Thou, I have to say that I'm constantly playing a Strat with volume rolled back... thanks to my picking style and the location of the volume knob/pot, hahaa :lol:
Tero
Finally the result of all this.
I decided to go with BKP Irish Tour -set. I have been using it for a while already and I have to say that it's a fantastic set for a "all-around 3xSC Strat". Enough toughness and power but not too much. Enough brightness and clarity but not too much of that either :)
Very well balanced set. The next axe I'm going to get (Suhr/Tom Anderson/or similar top-quality SuperStrat) with HSS-config will definitely have Irish Tours in middle and neck position.
Thanks for everyone who helped back in the days.
Congrats! They're fine pickups and quite versatile.
