Author Topic: Suggest Me A Pickup (single coil)  (Read 2645 times)
FrankZappa09
« on: September 20, 2011, 03:58:39 AM »
Hello, first post. I already have an aftermath bridge in my rg1570 and going to get my AM neck on wed.
The v pickups in this guitar are very noisy and I would like to also replace the single coil.
I play alot of metal(pantera, testament, megadeth..)  shred (paul gilbert, steve vai) but also a fair bit of rockabilly type stuff (reverend horton heat, brian setzer) also a ton of fogarty and zappa.
I know I cant have it all, but suggest something fairly versitile with a good volume match for the AM set please.
Thanks.
Also whats this about flipping the magnet for an ibanez 5 way?
« Last Edit: September 21, 2011, 11:23:48 PM by FrankZappa09 »
Transcend
Re: hSh aftermaths ibby rg1570
« Reply #1 on: September 20, 2011, 06:13:59 AM »
for the neck parrallel mode in a H-H setup which is position 4 you will get a lot of hum unless the magnet in the neck pickup is reversed.
Im not sure how you would go about this in the HSH setup as i dont know if it has that mode.
Do you have the ibanez pickup diagram?
FrankZappa09
FrankZappa09
« Reply #3 on: September 21, 2011, 01:07:44 AM »
No reccomendations for a single coil?
Also which magnet? Ive only taken one apart before and it had 2 magnets in it.
Another thing. If I wire it as a 3 way with no coil split I wouldnt have to do anything right?
« Last Edit: September 21, 2011, 01:18:29 AM by FrankZappa09 »
Transcend
« Reply #4 on: September 21, 2011, 06:29:56 AM »
yeah i think with that you will still have to get the neck magnets switched.
BKP will do this free of charge if you specify when ordering.
If you do it as a 3 way then you wont need to change anything.
Transcend
« Reply #5 on: September 21, 2011, 06:30:31 AM »
and as for you single coil requrest i can't really help you there as i have no knowledge of them at all
FrankZappa09
Re: Suggest Me A Pickup (single coil)
« Reply #6 on: September 21, 2011, 11:25:58 PM »
So, i've changed topic name, please someone suggest a single coil.
At this point I'm leaning towards a dimarzio Air Norton S, but I don't have any experience with single coils.
Thanks for the help Toe Knee.
« Reply #7 on: September 22, 2011, 12:08:07 AM »
Trilogy will match the contemporay tones of both hb, has 12.5 and will still do more classic stuff. If you want real vintage tone with fat mids, look at the Slowhands.
