Author Topic: Jackson 7 string Advice - Not too happy with the HD7 Bridge  (Read 5735 times)
djpharoah
« on: September 22, 2011, 11:14:36 PM »
So in my Jackson 7 string (27", Maple neck thru, mahogany wings, maple top) I have a set of calibrated HD7s (A5 both).
I love the neck and it's very smooth however the same can be said about the bridge. It's really smooth and I like my bridge to have a bit of aggression/bite to it.
It's something that's just been bothering me recently and got accentuated when I got my Mark IV. It was like Santana smooth on the bridge which is kind of hard to play chugging metal riffs on :lol:
Looking at BKPs mainly or even SDs CS pickups. I want something with a bit of a scoop and tight rhythm sounds but not harsh on the treble side. Would prefer A5 but ceramic is an option.
HALP!
Re: Jackson 7 string Advice - Not too happy with the HD7 Bridge
« Reply #1 on: September 22, 2011, 11:45:31 PM »
It will probably not solve everything, but have you toyed with the height? Might help a bit.
Otherwise maybe a Nailbomb or Rebell Yell?
djpharoah
« Reply #2 on: September 22, 2011, 11:54:53 PM »
I have and all it did was bring the pickup with more presence and attack. I'll give it a try again tonight.
sixgunsovertombstone
    • Check the epic shred
« Reply #3 on: September 23, 2011, 01:34:42 AM »
Something slightly scooped and can chug like a mutherfocker sounds like a description I would give my ceramic nailbomb. I have the 6 string version and its really aggressive and tight. I think it would work really well for 7 string stuff. I also have the alnico nailbomb which is also awesome. Its definitely not scooped, but rather even sounding. Its still aggressive and can chug like no ones business. I like the alnico nailbomb more, but if I played a 7 string or detuned really low I might lean toward the ceramic nailbomb more.
I also have a HD, again mine is 6 string version. I kind of hear what you are talking about, it is very smooth, but works for me for thrash type stuff. I think it might be a little lax on a 7 string though, especially since those are mostly aimed towards heavy rhythm playing whereas the HD is more a lead shred pickup... which is what I wanted. The nailbombs are both great on lead stuff. Ceramic is more aggressive and a little brighter while the alnico is smoother... Both would work I think.
BKPs: Nailbombs, Ceramic Nailbomb, Holy Diver, Rebel Yells, Blackhawks, Aftermaths
JacksonRR
« Reply #4 on: September 23, 2011, 04:26:34 AM »
I've had more than one passive pup drive me nuts dialing in correctly. Mostly it's a balancing act between the overall height of the pup and the height of the adjustment screws. I don't own a holy diver so I can't say what it likes, but you should try it. If you leave your tone control wide open all the time, maybe consider doing a small alteration to cut bass instead to tighten things up a bit. Using the proper capacitor will allow you to cut the muddies and clear you up. I really like the MM bridge for chugs, but it's my only BKP atm. I can say that I like using a passive bass cut with it. If you really like the thick and chewy mids of an alnico bridge, it's surely worth a shot. Are you using a Tubescreamer or similar pedal between your axe and the Mesa?
djpharoah
« Reply #5 on: September 23, 2011, 05:00:47 AM »
I've tried with the heights and the pole pieces. I'm using OD808 in front of the Mesa.
I'm also thinking of Cold Sweats.
« Reply #6 on: September 23, 2011, 05:27:21 AM »
miracle man
Transcend
« Reply #7 on: September 23, 2011, 06:30:37 AM »
Your description says miracle man without a doubt
mattc
    • Fool's Game
« Reply #8 on: September 26, 2011, 02:51:33 PM »
C-Bomb or Cold Sweat.  For that bite I think you need the ceramic magnet.
BKPs: Black Dog (b) Slow Hand (n), Emerald (set), Holy Diver (set), C-Bomb (b), VHII (set), Rebel Yell (b) MQ (n), Mother's Milk (set)
« Reply #9 on: September 26, 2011, 10:50:12 PM »
Miracle man, or possibly even aftermath. Stop scooping: you don't cut through and scooped guitar tones in a band mix sound like total ar5e, with no exceptions. Learn to use mids and your tone will improve dramatically :)
Alex
« Reply #10 on: September 26, 2011, 11:02:33 PM »
I understand that feeling. I've replaced the HD with a Miracle Man now. It has a lot more low end definition and overall clarity to it, but is also quite a different sound. I've always been a big fan of the MM, though. That guitar is tuned to B standard btw, 27" scale.
If you like the general sound of the HD, but want more aggression, the Nailbomb would be closer but more aggressive/metal.
