Guitar switching
Started by Slartibartfarst42, September 25, 2011, 09:52:19 AM
I know this exists, I just don't know what to look for that will do the job, perform well and be a good price.
I change between guitars during a gig, depending on the song we're playing and at the moment I unplug one guitar and then transfer the wire into the new one. I'd rather have both guitars plugged into a pedal at the start of my chain so I can simply press a button to determine which guitar is active. I'm guessing this is called something like an A/B box or A/B/Y box as I seem to recall reading about them before but I can't find such a product at the moment as I'm not sure what it's actually called or who makes them.
Transcend
I think Palmer makes something like what you are looking for
lehle or this one (adds a passive volume pot so you can dial down the hotter of the two guitars if you wish):
http://www.tonebone.com/re-bigshot-io.htm
Sancho
All good recommendations, but even Boss make something that would get the job done (although I usually steer people away from Boss)
When I try to use it to switch between amps, it creates a ground loop, but I would assume you won't have this problem when using it to switch guitars.
Hey Nonny Nonny mylord!
Cost is certainly a factor here and I assume that Boss will be plentiful on Ebay. I found a Boss LS-2 that sounds like it is the same idea as the AB-2 but I have no idea how good it is.
Sancho
The LS-2 is a loop selector, and will probably be overkill if you just want to switch between two guitars.
One thing to remember : if you switch guitars, be careful with your cables, because it's very easy to pull them off the stand...
you just need an A/B box, all these suggestions are WAY overkill.
heres a wiring layout - you could make one for £20, easy - there is probably someone on ebay selling bare-bones A/B switches for around the same price.
http://www.generalguitargadgets.com/pdf/ggg_sw_ab_lo.pdf?phpMyAdmin=4a28f86a515b7883e7bc35a68d4e7b6d&phpMyAdmin=78482479fd7e7fc3768044a841b3e85a
JacksonRR
I bought an A/B switch from a guy on Ebay who makes them to order. I'll try & get his details as it was inexpensive and works a treat.
Great, thank you very much, I'd really appreciate that.  :D
juansolo
#13
Quote from: Sancho on September 25, 2011, 05:58:37 PM
They need to be a little clever when you switch between amps to prevent ground loops. Switching between guitars however is an absolute doddle.
[url="http://stompage.juansolo.co.uk"]http://stompage.juansolo.co.uk[/url]
juansolo
Quote from: HTH AMPS on September 25, 2011, 08:43:13 PM
Nailed on, that's all there is to it.
