Author Topic: Nailbomb Set. 2 and 4 conductor + 3 ways switch + 1 volume pot= Wiring diagram?  (Read 4875 times)
With Full Distortion
  • With Fear I Kiss The Burning Darkness
    • Youtube
Heya Guys
how are you???
i have a question for you here.
i have a nailbomb bridge with 2 conductors. and a nailbomb neck with FOUR. all my previous BKPS had 2 conductors.
and now im going to use only one volume pot. and a 3 way switch.
so.. is there any diagram for this combination???
should i put the adjustable screws of the nailbomb neck towards the neck??
Thanks in advance
JP
That's easy.
On the four conductor, solder the green and white together. Then treat the pickup as a two conductor. Try red to switch and black to ground. If it's out of phase with the other pickup when both pickups are on, reverse black and red.
Good luck!
Stephan
    • Youtube
That's easy.
Good luck!
Stephan
Top class
Easier than i thought it wasnt
q: p
Thanks
JP
