Author Topic: Modern metal: BD vs. RY (bridge) + VHII vs. Mule (neck)?  (Read 10712 times)
Nolly
  • Global Moderator
Re: Modern metal: BD vs. RY (bridge) + VHII vs. Mule (neck)?
« Reply #15 on: October 08, 2011, 10:49:54 PM »
The clips are there so you can make your decision. Choose the one you prefer!
If you want to go for the Painkiller bridge, the matching neck pickup provides a very defined and woody tone not that dissimilar to the VHII but a lot hotter. With that said, it is brighter and hollower than the Cold Sweat you didn't enjoy before, so I stand by my recommendation of the Aftermath neck.
I still think you should choose the Aftermath bridge over the Painkiller, but that is up to you.
Alex
« Reply #16 on: October 09, 2011, 12:30:10 AM »
Based on the original post I can recommend the Black Dog, especially for such low tunings. It works very well in baritones and it is plenty tight. No idea what problems Eric had with his. I also find the top end very good for single note runs, it has a clarity to it that is very PAF-ish, for lack of a better word.
Euthanasia
« Reply #17 on: October 09, 2011, 01:04:21 AM »
Sounds good! so BD it is (:
Thank you all for your answers!
Just another question (which I asked earlier) to master Nolly:
"Shouldnt the VHII be a brighter pickup than the Mule? It sounds brighter in  the clips. I like the VHII's shiny highs but sounds like the mule sounds sweeter and warmer in the lows.
Why the VHII  would be a better choice?"
Nolly
  • Global Moderator
« Reply #18 on: October 09, 2011, 10:37:52 AM »
The VHII has more body to the midrange, but a brighter top end. The Mule has a very balanced midrange, with a rounder/warmer low end. The top end is bright, but rolls off before the VHII. The VHII's low end response is a lot tighter/more direct.
While the difference in DC resistance isn't that large, the VHII's AV magnet pushes a lot harder than the Mule's AIV. The result is that the Mule is a more open/uncompressed sound which works very nicely for clean and dynamic mid-gain tones, but isn't as fluid as the VHII when it comes to high gain sounds. (The VHII is still not a compressed pickup though, just in comparison to the Mule).
I recommended the VHII over the Mule because in a guitar like yours, I think you will find the VHII's midrange warmth enjoyable, while the clearer low end should prevent things getting muddy given how far you downtune.
Euthanasia
« Reply #19 on: October 09, 2011, 07:39:39 PM »
So BD and VHII it is!!
Thanks alot master Nolly! (:
