Author Topic: Abraxas Pick up Height  (Read 5705 times)
MGW
« on: October 04, 2011, 06:05:41 PM »
Help!
I have fiddling around trying to get the best height for my ne Abraxas Pickups in my PRS Custom 22, has anyone got and measurements to help me with, realy epreciate it .
Thanks
Mark. :D
Re: Abraxas Pick up Height
« Reply #1 on: October 04, 2011, 06:33:24 PM »
around 3mm from the strings is my default height for humbuckers - use your ears and adjust from there, only you can know if it sounds right for you.
« Reply #2 on: October 05, 2011, 01:50:25 AM »
That's a good starting point. I did some tweaking before I got the sweet spot (Crawler in HSS-swampashstrat).
MGW
« Reply #3 on: October 05, 2011, 02:19:04 PM »
Thanks Guys, I think it just at the last frets the strings dont sound as ringing clear as say half way up the neck, which I guess is normal?  I am adjusting all the time to get the same sound at the last fret as half way up the neck which i dont seem to be abls to!
Mark :D
« Reply #4 on: October 05, 2011, 03:28:34 PM »
Since the last frets are very close together it is more difficult to fret the string accurately. Also, the higher frets do naturally have lower sustain than the frets up to the 12th. Just make sure to set the pickups only so high that the strings are warble-free when fretting the last fret.
MGW
« Reply #5 on: October 08, 2011, 06:44:27 PM »
Thanks Stephan I have adjusted pickups so I dont have that Flubby sound on low frets, they are low, lower than 3mm more like 4.5. Not as loud but the tone dosent sound so off on the lowwer frets.
All the best
Mark.
sjwebb90
« Reply #6 on: October 09, 2011, 12:02:03 PM »
I have three PRS's one with Rebel Yells, one with Crawlers and the other with VHII's. The distance that worked on all three on mine was 2.5mm top and bottom E's. I also removed the 180pf caps, as to my ears gives a slightly warmer sound.
At the end of the day its all really down to personal preference.
MGW
« Reply #7 on: October 09, 2011, 01:46:10 PM »
Thanks for that, I find its hard to get 'Warble' free at the lowest frets unless you realy lower the pickups but it seems you allso lose some of the gritty character and tone of the pickups.
Cheers
Mark.
Sir_Palomid
    • Artland's Homepage
« Reply #8 on: October 31, 2011, 07:23:35 PM »
How would you describe difference between Rebell Yells, VH and Crawlers in PRS?
Which of them is more juicy, richer, fatter?
Still looking for tone I would like, tried Nailbombs and HolyDivers, but didn't liked them a lot.
Happy With What You Have to Be Happy With
