Author Topic: DIY Small Amp Suggestions  (Read 8674 times)
ToneMonkey
« on: October 12, 2011, 05:29:42 PM »
I've been hammering down the finer detail of my project guitar and I think I've got it prety much nailed. So now I'm turning my attention to the amp. I'm not going to be able to do anything on the guitar until I move house, but I might be able to squeeze an amp project under one of the sofas.
The guitar is going to be loaded with P90's and I'm after an amp that will deliver a nice old Vox or Fender amp sound. I play guitar like Dave Lister, so I don't need anyone to be able to hear me other than myself, therefore I'm after something around 3-5W. The idea around the project guitar is to keep it all simple, so I don't really need any controls other than one for volume and one for gain or tone.
I fancy breaking out the soldering iron, so I'm after building it myself.  I'll consider anything whether it be a kit or just a set of schematics. Don't mind building the chassis if I need to. Ideally I'd like to make it into a combo with a small speaker cab as I want to keep it as small as possible.
I know there's a few amp guru's around these parts, so any suggestions would be appreciated.
Cheers guys
forestcaver
    • My DIY Guitars
Re: DIY Small Amp Suggestions
« Reply #1 on: October 12, 2011, 06:27:33 PM »
Strongly recommend ampmaker...
« Reply #2 on: October 12, 2011, 06:32:55 PM »
I've never bought anything from him (Barry) but did sell him may Martamp. He's a nice guy and I've heard good stuff about his build kits. Check out youtube, there are some pretty good demos on there.
ToneMonkey
« Reply #3 on: October 12, 2011, 07:05:28 PM »
Cheers guys. I've already looked at the ampmaker kits but I'm seeing if there are any other alternatives.
jpfamps
    • http://www.jpfamps.com
« Reply #4 on: October 12, 2011, 08:29:20 PM »
There are plenty of other kit options, however I the Ampmaker kits have the best instructions.
Some other options are:
http://www.madamp.biz/
http://www.torresamps.com/ (Barry Vyse at Torres is very helpful).
http://www.mojotone.com/ (you can order these through AllpartsUK)
http://www.astonelectronics.co.uk/
http://www.valvepower.co.uk/18w_kit.htm
Alternatively there is nothing stopping buying the bits and making your own "kit".
« Reply #5 on: October 13, 2011, 10:26:34 AM »
That sounds like a single ended amp. Fender Champ or Vox AC4 come to mind. Also check out www.ax84.com for more beginner guitar amp projects.
ToneMonkey
« Reply #6 on: October 13, 2011, 03:22:21 PM »
That's my thinkning at the minute. I think I'd be fairly happy making the chassis, turret board and other bits in the shed as I want to keep the price down while still getting the best sounding mini amp that I can.
I'll have a good look at the links when I'm back from work.
Cheers again guys........
........ not to sure how I forgot about ax84.com. I'm sure I used to be a member there a few years back.
jpfamps
« Reply #7 on: October 13, 2011, 04:39:39 PM »
Allparts do the Mojotone transformers, which are good quality.
Tube Town in Germany all do some good torroidal mains transformers, which are good value. For example this would be a good choice for a champ-style 5W amp (without valve rec):
http://www.tube-town.net/ttstore/product_info.php/info/p527_Torodial-50VA.html
If you are going to bash your own chassis I would advise getting an ali chassis, as this will be much easier to work. There would no need for the extra strength of steel on a 5W amp.
There are plenty of people selling turret/ eyelet boards out there. We use 3mm PTFE, which very easy to work and electrically the best material to use.
ToneMonkey
« Reply #8 on: October 13, 2011, 05:59:44 PM »
Cheers dude. I'll look them up. Sadly although I'm now home, I'm still working so I'll have to have a look later.
I had some ali sheet in the shed a while back, but god knows where it is now.
I'll hopefully be heading over to our office in the West Midlands next week and last time I was there I noticed a transformer winding place near the office. I may pop my head in there for a nose when I go over. I highly doubt they'll have somthing suitable but it could be worth popping in for a cup of tea and a chat.
  • Truly bad since 1972
« Reply #9 on: October 13, 2011, 07:13:58 PM »
Ive helped a mate mod a ampmaker kit very nice amps, I have also had a 5w one from here http://www.astonelectronics.co.uk/valve-amp-kits-tube-amp-kits.html and still own it.....is a great little amp with easy instructions to build, guy is also helpful if you get stuck
ToneMonkey
« Reply #10 on: October 13, 2011, 07:55:21 PM »
I'm really liking the look of the Torres Tiny Tone. I think the best idea is to get the instruction book (£20) and slowly start to accumulate some parts until I only need the speaker and the transformer, that way I can sneek it past the wife until I can say 'If I buy a transformer and a speaker, I can build an amp..... no dear, not that kind of transformer'.
Sounds like a plan.
ToneMonkey
« Reply #11 on: October 20, 2011, 06:58:25 PM »
I've been doing some more reading and I think you have it 100% right with the AC4, so cheers mate.
I've got the schamtic from here:
http://website.lineone.net/~m0dzo/AC4TVschem.pdf
Although the actual amp is a pcb, I'm presuming I can make up my own turret board. If you can't, can someone stop me before I start to buy the bits  :D
