I need help regarding string spacing extremely badly!
Started by Nephilim, October 23, 2011, 10:33:18 AM
Nephilim
As people know. Hardtail = 50mm; Trem = 53mm. That I know. The thing that has really confused me, and got me worried is that, when I get my new Epiphone, I'm going to replace the hardware, and every tail piece for them type of guitars (Gibson) say 52mm. I already have my MM Set in 50mm, so you can see why I'm worried :/ Help me please!
marauder
Don't worry.  I've got a Jackson with a floyd on it with a standard spaced HD, and it sounds fine.  It's more a cosmetic thing than a sound difference.
My Explorer has a standard spaced BD, and the spacing is slightly wider, thats probably like your LP will be.
If the spacing at the bridge saddles is 52mm then it narrows a bit by the time it gets to the humbucker - maybe about 50.5-51mm so standard HBs will work fine.
remember that the magnetic field is bigger than the polepiece size anyway - so you wont notice any problems
Nephilim
Quote from: FELINEGUITARS on October 23, 2011, 02:13:08 PM
Thanks very much. This is probably a good question to ask you since you make Les Paul Style guitars. But on my current Epiphone, I replaced the Tailpiece and tune-o-matic bridge with official Gibson ones, and I found the Gibson metal cylinder things, which are in the guitar body, in which the posts screw into, had a slightly bigger diameter. I just wondered if you know of any other good bridges to replace my new Epiphone one with? Cheers
Quote from: Nephilim on October 23, 2011, 02:22:17 PM
TonePros.  Look for ones which say Metric fit, and Large Posts.  Simple as that!  :D
Quote from: Philly Q on October 24, 2011, 12:27:55 AM
Which I keep in stock.......
Quote from: FELINEGUITARS on October 24, 2011, 01:42:27 AM
... and work very well
Jonathan fitted some tone pro studs and an aluminium Gotoh bridge on one of my Vs a while back. Initially the jury was out on if it had made much of a difference. A few gigs down the line and I can say the difference is both quite clear and noticeable. A dollop of extra sustain and theres somehow a bit of extra touch sensitivity/mojo (call it what you will!).
Quote from: gwEm on October 24, 2011, 10:15:24 AM
Aluminium bridge, or tailpiece?  :?
I think it does make a difference.  I haven't actually done a tailpiece swap on a guitar with a tune-o-matic (yet), but on my Junior guitars with wraparound bridge/tailpieces the aluminium seems to sweeten the tone a bit, maybe takes out some harshness in the mids.  I don't think it's increased the sustain, but the initial attack of the note is bigger and (to trot out a cliché....) "piano-like".
It's the sort of mod which might work on some guitars and not on others - but of course it's very easily reversible and you can always use the tailpiece somewhere else.
tailpiece indeed
edit: its strange, because i could really feel the difference plugged in.
Yes - I have become somewhat of a fan of Aluminium tailpieces
Like PhillyQ says they do seem to sweeten and open up a guitar tonally
I have been using the Gotoh ones with good effect.
The other thing I do is use the tonepro studs that clamp down on the top of the tailpiece
I feel this gives much better transference of vibration from strings to body as it all locks down and give complete contact/coupling with the top and bottom surfaces of the tailpiece.
I much prefer these to the tailpieces with the grubscrews since I feel you get more solid contact and vibrational transfer
They are a popular option on my custom built Lion models and will be standard on my 20th anniversary model which will be out im the new year
This is a body shot of the prototype (fitted with Abraxas humbuckers currently)
