Author Topic: Pickups for Jackson SL3 Soloist  (Read 5553 times)
Anarchia
« on: October 27, 2011, 03:52:35 PM »
Hi all, I'm looking for a bridge pickup for my Jackson. It is a neck through but naturally bright sounding guitar. It currently has a Duncan JB in the bridge and two Hot Rails in the neck and middle. I need a bridge pickup which is capable of playing thrash (a la Megadeth) but most importantly to give a singing lead tone with good note clarity on fast runs. Also, the guitar sounds quite thin in the highs right now, and I want something to fatten them up. I'm looking for a sort of juicy lead tone, similar to Marty Friedman's, but I want to retain note clarity so it doesn't mud up when playing across the fretboard.
Re: Pickups for Jackson SL3 Soloist
« Reply #1 on: October 27, 2011, 04:00:51 PM »
You have described the Holydiver.
Sancho
« Reply #2 on: October 27, 2011, 04:42:05 PM »
I've put a Holydiver in my SL1. Will take it to rehearsal tomorrow to try it through a big rig, but at home it sounds pretty nifty.
I don't know if it would be my first choice for thrash though, but it definitely fits your description of lead tones to perfection.
Hey Nonny Nonny mylord!
« Reply #3 on: October 27, 2011, 05:24:57 PM »
The Diver is stellar for those leadtones, Nailbombs will do trash a bit better.
Anarchia
« Reply #4 on: October 27, 2011, 06:34:59 PM »
Well, I already get a good thrash rhythm tone out of the JB through a Blackstar HT5 (using a crummy MG15 as a cab for now :() so surely a Bareknuckle would surpass that. So long as the rhythm is good, I'm happy, but I mostly only play lead. Should the Holy Diver do that, then?
Anarchia
« Reply #5 on: October 27, 2011, 06:54:46 PM »
Oh, and how is the Holy Diver for pinch harmonics? Thanks.
Alex
« Reply #6 on: October 27, 2011, 06:59:47 PM »
I'd recommend the Nailbomb over the Holy Diver, because it has that nice bottom end chunk. Definitely better for thrash than the HD. I felt the HD excelled at Motley Crue-style sounds, but for palm muting it didn't have the presence on the low strings.
My voodoo LesPaul also suffers from a bit thin sound on the high strings - I think that is often a problem with ebony fretboards btw - and the Nailbomb thickened the treble strings up nicely.
Sancho
« Reply #7 on: October 27, 2011, 08:34:05 PM »
Yep, I'm not  too impressed with the HD's bottom end thump. It may be the one area where I find it lacking.
ElectricTurkey4369
« Reply #8 on: October 27, 2011, 08:39:18 PM »
+1 about the HD's lack of Bottom end, BUT,
that doesn't make it a bad pickup. I love it!
Alex
« Reply #9 on: October 28, 2011, 12:44:45 PM »
I didn't perceive is a lack of bottom end, more of the lack of chunk and low end presence.
« Reply #10 on: October 28, 2011, 02:28:00 PM »
the holy diver has a quite flat bass, although it has a nice amount of low mids
it needs to be set quite close to the strings, specially the bottom ones, so you get maxed bass response and picking attack
if you want extra bass, try the alnico miracle man
it's a lot like the diver, but bassier and slightly more compressed (but not fuzzy like the warpig)
http://www.youtube.com/watch?v=T1RafxMYU5w
blackie
« Reply #11 on: October 28, 2011, 05:23:52 PM »
painkiller?
« Reply #12 on: October 28, 2011, 05:58:58 PM »
I never feel the Holydiver lacking in bass, even though it does not have as much of it as the Miracle Man. However, compared to a Duncan JB the Holydiver is a bass monster! For the bass punch make sure that you got the right amp. I have never played a Blackstar HT-5 but if it's only 5 Watt and single ended you will not get much low end punch with any pickup. Low frequencies need the most power from the amp, and 5 watts just don't cut it.
Sancho
« Reply #13 on: October 28, 2011, 06:10:29 PM »
Tomorrow I'm taking two Soloists to rehearsal. One with a Holydiver, one with a JB. So that will be a pretty direct comparison...
I think my Splawn Quickrod has more than enough power to get the bass pumping :)
« Reply #14 on: October 28, 2011, 06:14:01 PM »
Definitely. That is a very bassy amp going by the schematic - never had the chance to play one though.
