Author Topic: Still searching for the ideal Strat humbucker...  (Read 2638 times)
Pierre
« on: October 31, 2011, 08:52:32 AM »
Man this guitar has seen A LOT of pickups:
Seymour Duncan Jazz. Very clear and tight with gain but a little anemic on clean (too low output)
Alnico II Pro: so far the best choice, but I wanted something a little ballsier
SD PATBII: too middy
SD brobucker: too middy
Bareknuckle Crawler: very nice, but a little too high output
SD '59: very nice as well, but bright and not as ballsy
I'm pairing it with two SD SSL1s single coils, and I have my very own wiring (bridge/splitbridge + mid/split brige + neck/neck + middle/neck) on a megaswitch.
This guitar is pretty big sounding. Not overly bright, pretty clear. A big Strat sound. I'm looking for a humbucker that will complement this; keep on giving me the Strat tone in position 4, while having a big rock sound on position 5.
So it would seem that on my wishlish I have a 'wide sounding' (god I hate tone buzz words), around 12K (compared to my other pickups which were 10K and too light) wound humbucker. Something with the same thickness of tone as the Crawler, but a little less output.
Any ideas? Thanks y'all :)
Re: Still searching for the ideal Strat humbucker...
« Reply #1 on: October 31, 2011, 09:04:40 AM »
I'm thinking that a VHII in a Strat would sound pretty much perfect...
« Reply #2 on: October 31, 2011, 09:51:19 AM »
I had the same issue with the Crawler in my PRS-style Swamp Ash Special. Based upon Tim's recommendation I chose the Abraxas and it was perfect. Hotter PAF tone, less output and mids than the Crawler, splits excellent. Tim's alternative recommendation was the Emerald.
« Reply #3 on: October 31, 2011, 12:56:45 PM »
That's the Abraxas. Btw, I have the Crawler and VHII in my (swamp)ashstrats. I like the VHII more and more every day. The Crawler, as you know, is quite versatile. The Abraxas is a less hotrodded Crawler with a bit more chime in the topend too.
Pierre
« Reply #4 on: November 02, 2011, 10:54:04 AM »
Thanks y'all :) I actually ordered a DiMarzio AT-1 after seeing the current BKP prices. Until I get a band I may not be able to justify these. However it does seem like the Abraxas would be exactly what I need and I wouldn't be surprised if I eventually succumbed to it  :lol:
« Reply #5 on: November 02, 2011, 11:34:18 AM »
I'm a bit late here, but I'd have also said Abraxas.
If I had multiple HSS Strats (which I might do, if I ever used my Warmoth parts mountain), I'd have one each of VHII, Abraxas and Crawler.  Maybe Holydiver if I was after an '80s metal sound.  From all I've read and heard, they just seem like the BKPs best suited to Strats.
Although I like vintage-sounding pickups, for me the true PAF-types don't quite work in Fender guitars, they sound a bit thin and weedy (unless they're in the neck position).
« Last Edit: November 02, 2011, 11:37:25 AM by Philly Q »
