Author Topic: ad60 vt pedal board.......help!!!!!  (Read 6325 times)
  • Truly bad since 1972
« on: November 04, 2011, 12:23:35 PM »
mate has aquired on of these but has weird connector for pedal board looks almost like lan connector. anyone any idea which pedal board will work with these
Transcend
Re: ad60 vt pedal board.......help!!!!!
« Reply #1 on: November 04, 2011, 12:55:46 PM »
i have no idea about what will work.
But you could just make a cable up with a different end
« Reply #2 on: November 04, 2011, 05:52:01 PM »
Good idea but find schematic and connector may be hard. That's before fact well beyond mine and his skills
« Reply #3 on: November 05, 2011, 11:29:10 AM »
apparently isnt just pots and switches has specific chip inside...damn you vox
Transcend
« Reply #4 on: November 05, 2011, 11:56:03 AM »
have you tried contacting vox?
« Reply #5 on: November 05, 2011, 12:08:24 PM »
vox vc12
http://www.gak.co.uk/en/vox-vc12-foot-controller-for-valvetronix/7315
vox vc4
http://www.zzounds.com/item--VOXVC4
might be hard to find, that looks like what you want. bet check it out more though. the vc12 has the LAN connector at least looking at the quick start manual pdf.
« Reply #6 on: November 05, 2011, 01:35:15 PM »
yes forgot to say tight budget..so second hand vc4 or 12 looks way foward
« Reply #7 on: November 05, 2011, 01:41:24 PM »
probably. whatever they did, its probably some proprietary vox thing. might have some wild logic in it.
MAKO amps use RJ45 connectors for their footswitch on at least 1 product, mainly because the cables are cheap & easy to buy (normal LAN cables) rather than 8pin DIN connector cables.
It wouldn't surprise me if Vox made it so you had to use their own footswitches with it. Hard to tell without more info.
« Reply #8 on: November 05, 2011, 01:49:22 PM »
very scetchy info on these...had a fcb1010 was hoping that would work as a great controller pedal
