11-56 gauge in C# with Floyd - would you risk it?
Started by Antag, November 08, 2011, 02:41:04 PM
Antag
I've finally found a set of strings that I like for detuning to C# - the D'Addario EXL117s:
11/14/19/32/44/56
They're great on my trusty RR1T (tune-o-matic bridge), but now I'm considering putting them on a guitar with a Floyd.  Do you think the tension would be too much?
Madsakre
Cattlepress
Loomer
Well, you will end up adjusting the trem springs, but that's about it. I'd say go for it.
Depends what strings are currently on there already.
You can calculate the string tension for each string, add them up for both sets and see how close you'll be. It might take another spring or two in the floyd, assuming the neck has enough strength to cope with the extra tension... they're not that heavy strings, I set my backup RG up with 13-60s in drop A (from 10s or 11s in standard tuning, I forget now it's a while ago).
Stevepage
Go for it. I done it with 12 - 56's tuned to E on the Carvin I had (which you played yourself when you sold me the Gothic V) and the trem handled it just fine.
Antag
Quote from: Madsakre on November 08, 2011, 02:44:07 PM
no
Is that no you wouldn't risk it or no you don't think the tension would be too much? :)
Cammi
The tension will be fine. Alexi from Children of Bodom plays Drop C with 11-50 and D Standard with 10-56, and al his guitars have Floyds, so you'll be perfectly fine :)
Loomer
Quote from: Cammi on November 08, 2011, 02:52:28 PM
Really? That's a weird setup  :?
But then again, the dude is from Finland. They're a bit odd usually.
I dont get why that is odd?
EDIT: oh i see
Cammi
Quote from: Loomer on November 08, 2011, 03:16:43 PM
Oh sorry i got the guages back to front lol
Transcend
Hey MDV what were those DRs i got off you? 13s?
I used those in C# on a baritone with and edge 3 of all things with absolutely no problems
JDC
I use 11/15/18/32/44/59 in C standard with a floyd so I think you will be fine
