Author Topic: Which replacement for my Country Boy?  (Read 3272 times)
stringtheorist
« on: November 10, 2011, 11:56:39 AM »
I absolutely love the tone of my Country Boy bridge pickup but it's way underpowered compared to my humbucker loaded guitars, and this imbalance is a pain as it means messing with my amp settings when I swap over. I would like to get a replacement with a similar tone but an output to equal the EMG humbuckers on my ESP Eclipse. Would the Piledrivers be a good choice or are these OTT for playing country? I don't mind a versatile pickup as I play metal too (usually use the ESP for that) but I don't want to sacrifice the guitar's function as a country/rock tool. Alternatively, would The Boss or Brown Sugar do the job?
BigB
  • Let's rock !
Re: Which replacement for my Country Boy?
« Reply #1 on: November 10, 2011, 01:01:59 PM »
No passive single coil pickup is going to get you the output level of an active 'bucker, and let's not talk about keeping the country boy tone. You'd be better using a clean boost to level out the guitars.
Note that you'll probably still have to mess with your amp's EQ...
« Reply #2 on: November 10, 2011, 05:36:39 PM »
The're is noting vintage that will hold up with any passive pickup. I agree: try a booster or eq-pedal, maybe in the loop.
BigB
  • Let's rock !
« Reply #3 on: November 10, 2011, 08:05:21 PM »
Since it's about hitting the front with a similar level, I wouldn't put the clean boost in the loop here... But YMMV ;)
Lucifuge
« Reply #4 on: November 10, 2011, 08:24:59 PM »
Or turn down the volume on the EMGs?
« Reply #5 on: November 10, 2011, 09:26:36 PM »
Have you tried his Father? You tele boys like to keep it in the family, I understand...
richard
« Reply #6 on: November 13, 2011, 02:10:32 PM »
I have different amp settings for all of my guitars. It's not that big a deal. If you love the sound of the Country Boy can't you just get used to adjusting your amp ? Once you've figured out the settings it only takes a couple of seconds to tweak a few knobs. Surely better than getting rid of a pickup you really like.
PRS S2 Singlecut RY's
JV Strat  IT Bridge
Gibson SG JB bridge
Fender Bassbreaker 15
Yamaha THR 100 Dual
Quilter Aviator Cub
