Author Topic: transformer isolation  (Read 5405 times)
« on: November 19, 2011, 07:25:32 AM »
So I've been up all night on the nightshift and looking at various things. This is nightshift round 1 and im feeling it!
I was looking at a couple of projects and got to spying something requiring a transformer with a ~235Vac 6VA secondary.
So not much power but close to UK mains voltage. This was an American article, so the transformer was stepping up 110Vac to 235Vac...
I started looking for a transformer that would do UK mains to 240Vac... then I remember UK mains is 240Vac... I briefly thought about the possibility of directly rectifying UK mains... putting live and neutral directly onto a rectifier. I then realised this is a stupid and dangerous idea.
so now I'm wondering what product just converts current, or if i wanted to get close to 240Vac into a rectifier, should I be looking at 110Vac dual secondary PT's?
Frank
Re: transformer isolation
« Reply #1 on: November 19, 2011, 07:42:48 AM »
I can't stress this enough
NEVER DIRECTLY RECTIFY MAINS VOLTAGE WITHOUT AN ISOLATING TRANSFORMER
Danbury do a handy range of valve amp transformers, I've used this one in the past for preamps
http://livinginthepast-audioweb.co.uk/xfrmrvt247.php
I think they've added a few more since I last ordered from them, have a check
« Reply #2 on: November 19, 2011, 09:04:50 AM »
I knew it wasn't correct as soon as the idea. I'm silly but not that silly. Still... I've not slept in over 24 hours so thought process is taking me a bit longer.
Thats exactly what I was looking for. cheers
If I used it for what I'm thinking, I feel like I'd have to mount it inside a chassis for safety. I'm not sure it would fit into what i'm planning. Now I know what I'm looking for I might do some googling when I'm back in work tonight and see what else is out there. I'd be using it for a snazzy dual polarity supply.
« Reply #3 on: November 19, 2011, 10:23:23 AM »
if you want 240v on the secondary, just use a 1:1 isolation transformer.
« Reply #4 on: November 19, 2011, 02:29:54 PM »
I'm struggling to find anything that is just a neat solution. small and just a toroid or something. The closest thing I know about is what Frank posted. Most things are just too big. hmm
jpfamps
    • http://www.jpfamps.com
« Reply #5 on: November 19, 2011, 06:59:16 PM »
Tube Town do a useful range of small (and large) toroidals, eg
http://www.tube-town.net/ttstore/product_info.php/info/p2192_Torodial-30VA.html
ToneMonkey
« Reply #6 on: November 20, 2011, 09:04:28 PM »
I'm 99% sure that the UK mains voltage is now classed as 230V to be in line with Europe.
It used to be 240V +/- 10% but they changed the tolerance so it's 230V +10% -5% (or something close), so nothing has actually changed other than the numbers.
