Purchasing Pickups...
Started by tim_miles, January 28, 2006, 04:01:11 PM
tim_miles
Heya Guys, im in the proces sof buying the Telecaster Brown sugar pickups and was wondering what the box that says
"Make and model of guitar to be retrofitted:" is for. Do i have to right anything in there?
it may seem like a basic question but dont want to type anything wrong just incase.
tim_miles
no worries!
pickups have been ordered! :D
For a tele you should be OK, it really applies to the humbuckers most.  It determines if you get a short leg (PRS, Ibanez I think too), or a long leg (Gibsons and everything else).  With a strat it can also determine the base shape (regular or EMG).  I can't think of anything that might change on a tele!
tim_miles
thanlks for the reply!
i put the fender standard telecaster mexican left handed under retro fit
was i wrong to do so or will it be ok??
thanks very much:)
shouldn't be any problem at all
tim_miles
thanks:):D
do u know what the shipping is on the pickups?
It'll be interesting you hear what you think of them.
tim_miles
illl let all of you know how it goes!
im getting the shop to install them because i really don't want to mess it up. i'd rather practice on some cheaper guitars before risking breaking my tele lol
thanks for all the help!
I recommend getting a 4 way switch to give neck/bridge series in addition to the usual parallel position- well worth it for minimal outlay- check out my Country Boy clip to hear the effect.
tim_miles
thanks! i think i will
http://cgi.ebay.co.uk/New-Fender-4-Way-Telecaster-Guitar-Mod-Switch_W0QQitemZ7385823838QQcategoryZ42455QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
is this the type of thing you mean?
also does a 4 way switch vary for right handed or left handed guitars as i'm lefthanded and don't want to buy a switch that only fits right handed guitars.
Also im getting my guitar done in a shop as i have never done a pickup change before and was wondering how much more a shop would charge to fit the 4 way switch? approximately. They gave me a quote of 35.00 for sheilding and they said that it would be next to nothing to fit the pickups as they are easy.
i would do it my self but on a 400.00 guitar im afraid for my first go. i'd rather buy some cheap guitars and practice on them and then work my way up.
thanks:D
Yeah that is the switch. I am not sure about l/h guitars but I would imagine that it is the wiring that matters- i.e. the tech will just reverse the wiring as the tags  are there anyway ( If Phil King checks this post I am sure he will correct me if I am wrong). I can't see it adding to the costs- he'd have to wire a switch in any even. With the switch back ( i.e. pointing to the neck you get the n/b series, then next indent is n then n/b parallel and then b. It means a slight adjustment in your thinking but it takes a few moments and then you have that extra oomph at your disposal. Everyone says it is easy to fit pups and I did see a tuition vid for Strats and it does look easy but, like you, I'd prefer to have someone else do it for me as I know then it'll be done for me. I am currenly working over 50 hours per week( I thought that it would ease up after Christmas) and that is another factor. You could always watch them do it to see how it is done. Good luck anyway.
tim_miles
thanks beatle when u say that when the switch is clicked all the way back towards the neck position u get the neck and bridge sound?
which position do you click the switch to to achieve just the bridge sound on the 4 way switch?
also if i kept the 3 way switch what would happen with that other wire that wasn't wired to the switch. would it be loose?
thanks
Hi, the 4 way would work fine in a left hand guitar.  Positions are:
back (to bridge): Bridge alone
pos 2: Bridge + neck Parallel
pos 3: Neck alone
forward (to Neck): Bridge + neck Series
tim_miles
heya guys, my pickups arrived today, they are stunning lol
will be having them installed sometime soon. I see there is instructions on how to install them to a 3 way switch. i was planning on buying a 4 way switch. will they still fit to a 4 way switch? or would i have had to included that when buying?
i hope they will be ok to go the 4 way switch.
enehelp wud be awsome:D
There is no problem to add a 4 way switch later, the wires from the pickup stay the same.
