Author Topic: Pickup height  (Read 9358 times)
Lucifuge
Pickup height
« on: November 30, 2011, 02:25:14 PM »
No, not another "how high should my pickups be" thread...
Rather I'm wondering, when people talk about the distance of the pickup from the string, eg 1/8" or whatever, do they measure with the strings open or fretted at the last fret, as the strings can be quite a lot closer to the pickups when fretted.
Re: Pickup height
« Reply #1 on: November 30, 2011, 02:42:48 PM »
I never measure - I just set the pickups to where they sound good to my ears.
Sancho
Re: Pickup height
« Reply #2 on: November 30, 2011, 03:08:13 PM »
I'm with Stephan. Measurements are pointless. Use your ears ;)
Hey Nonny Nonny mylord!
Re: Pickup height
« Reply #3 on: November 30, 2011, 03:14:20 PM »
I got in trouble once when someone quoted pickup heights in tenths of millimetres and I suggested it was (possibly) rather unrealistically precise... so I'll keep schtum.
Re: Pickup height
« Reply #4 on: November 30, 2011, 03:20:41 PM »
Fretted at the last is the usual measuring technique  :)
Keven
Re: Pickup height
« Reply #5 on: November 30, 2011, 04:29:09 PM »
I'd like to thank twinfan for the first useful answer in the thread :)
My BK's:
C-Bomb Set / Blackhawk Bridge
Holydiver Set/ BG50 Set
Re: Pickup height
« Reply #6 on: November 30, 2011, 05:04:06 PM »
What makes you so sure about that?
Re: Pickup height
« Reply #7 on: November 30, 2011, 06:21:08 PM »
Because that's the measurement Fender, Gibson and PRS etc give on their websites under their setup guides.
Keven
Re: Pickup height
« Reply #8 on: November 30, 2011, 08:30:22 PM »
fretting the string at the last fret ensures the measurements are taken at the string's lowest distance between the pickup. imagine setting it to 3mm from the strings on open strings and having the pickup hit the low E everytime you palm mute!
My BK's:
Re: Pickup height
« Reply #9 on: November 30, 2011, 09:45:38 PM »
Strings held down at the last fret for me
On humbuckers a quick way of getting them in place quickly is putting the X-Heavy BKP plectrum supplied with the pickups on top of the humbucker and raising the pickup till the pick just touches the underside of the strings
Then tweak to taste!
Re: Pickup height
« Reply #10 on: December 01, 2011, 01:24:34 AM »
For a starting point I tend to fret on last fret, put and put one of my 2mm picks in there. From there I lower (and get back up to this point again) to until I find my favorite spot. That spot usually is 1-2mm away from where I started from, so quite a lot, but I like to try a lot of different hights, although I never have them close to the strings, to get an idea how this perticular PU will react to the changes, which helps me eventually finding the sweet spot.
