Author Topic: PUPs and noise  (Read 2234 times)
Ochaye
PUPs and noise
« on: November 30, 2011, 11:58:12 PM »
the BKs any noisier you think than the stock gibbos?
see the reason i am asking is when my hands are off the strings the noise levels are quite loud (hum) compared to my stock gibbsons in my other LP...i am aware that levels of noise and hum rise when hands are removed from strings it's just that i did not expect the BKs to be noisier this way compared to the gibbos
to be fair it might just be that the installation was/is not very good ( i don't have the tools to check) ........i had to take it back, twice, due to faulty sloopy solder joints.whaddya think guys,how are your potted MULES compared to whatever you removed for your BKs for noise/hum levels?
Re: PUPs and noise
« Reply #1 on: December 01, 2011, 12:15:38 AM »
I don't have Gibbo's (had some) but my BKP's are silent, at least not noisier then anything else I had.
Shag101
Re: PUPs and noise
« Reply #2 on: December 01, 2011, 03:08:15 AM »
Might want to check the wiring again.  Sounds like a bad solder joint..  :D
I have no noticeable hum difference with my hands on or off any pups.  (Gibson and BKP included)
Warpig = '88 Charvel Model 1
Re: PUPs and noise
« Reply #3 on: December 01, 2011, 08:25:03 AM »
Are you comparing lilke with like?  If your Gibbo pickups had covers, and your BKPs don't, that will be the reason they're noisier....
Re: PUPs and noise
« Reply #4 on: December 01, 2011, 10:24:53 AM »
+1. In some Gibsons there is no string ground. To keep noise down all the circuitry is shielded in a metal box, and the pickups are shileded by the metal base plate and the covers. If you take off the covers or replace the original covered pickups with uncovered ones the shielding cage is broken, and you will have more hum than designed.
« Last Edit: December 01, 2011, 10:31:56 AM by darkbluemurder »
Ochaye
Re: PUPs and noise
« Reply #5 on: December 01, 2011, 04:09:58 PM »
covers on folks
Re: PUPs and noise
« Reply #6 on: December 01, 2011, 04:25:20 PM »
Possibly bad solder joint(s)?
Ground loop somewhere?
BKPs much closer to the strings than the Gibsons? Could try dropping them away a touch?
Just a few thoughts...
