November 23, 2026, 01:31:18 AM
Main Menu
Main Menu
Home
Search
Bare Knuckle Pickups Forum
Forum Ringside
Pickups
VHII Question
VHII Question
Started by darkbluemurder, December 08, 2011, 05:44:41 PM
Previous topic
Next topic
Print
Go Down
Pages
1
User actions
Welterweight
Logged
VHII Question
Hi folks,
I have read many times that the VHII has asymmetrical winds but
1. do both bridge and neck versions have asymmetrical winds and
2. which coil has more winds on it - the screw coil or the slug coil?
Thanks and kind regards,
Stephan
Light Heavyweight
Logged
Re: VHII Question
#1
December 08, 2011, 06:17:54 PM
1) Probably
2) No idea
Helpful aren't I? :lol:
4Eyes
Junior Flyweight
Logged
Re: VHII Question
#2
December 08, 2011, 06:39:26 PM
1. I would say yes, because it's a part of it's sound. but it's question for Tim at BKP
2. I think that screw coil has more winds than slug coil. the main "job" of slug coil is to cancel the hum
Keller guitars 6 string exotic with bkp pk/vhII
Light Heavyweight
Logged
Re: VHII Question
#3
December 08, 2011, 07:28:45 PM
But the slugs are normally used when split, so I would put extra on those if it was me....
4Eyes
Junior Flyweight
Logged
Re: VHII Question
#4
December 08, 2011, 10:52:05 PM
are you sure? I thought that slug coil is wired to the ground when push pull pot is pulled out :)
Light Heavyweight
Logged
Re: VHII Question
#5
December 09, 2011, 08:22:05 AM
Last Edit
: December 09, 2011, 08:24:01 AM by Twinfan
I'm sure. The 'start' or 'hot' of a humbucker is usually the slug coil - see these BKP diagrams:
http://www.bareknucklepickups.co.uk/main/downloads/schematics/general/humbuckers/humbucker_colour_code_conversion_chart.pdf
http://www.bareknucklepickups.co.uk/main/downloads/schematics/general/humbuckers/2_hum__2_vol__2_push_pull_tone_coilsplit__3_way_toggle.pdf
For humbucker operation, a BKP has green/white together and earthed, red is 'hot' and black is earthed too. If you split one, green and white go to earth therefore you're seeing red - green, the slug coil ;)
Unless you wire it 'backwards' then you can have it the other way instead....
4Eyes
Junior Flyweight
Logged
Re: VHII Question
#6
December 09, 2011, 10:04:00 AM
yep, you're right. I don't know why I thought that opposite is true
Welterweight
Logged
Re: VHII Question
#7
December 09, 2011, 11:14:32 AM
Thanks guys!
Since I have a neck pickup I will measure and post the results. I don't have a bridge pickup yet. And I was not sure which wires belong to which coil but everything said so far makes perfect sense.
Once again thank you very much.
Print
Go Up
Pages
1
User actions
Forum Ringside
Pickups
VHII Question
User actions
Print
