Author Topic: Thick sounding Painkiller...like, really thick  (Read 5500 times)
ethan_hanus
« on: December 09, 2011, 06:10:46 PM »
I just did this today with the Liquid Drive pedal I built by hand, using a TS9 as a boost. Amp is a Valveking 112, played in Drop B. It sounds so thick it's crazy.
http://www.youtube.com/watch?feature=player_profilepage&v=NHHyjvCH4No
Working on it.
Aizaku
    • theMachineandI
Re: Thick sounding Painkiller...like, really thick
« Reply #1 on: December 09, 2011, 10:16:24 PM »
That was really good and crunchy, like a mouth full of Pringles.:) I use a Painkiller in the neck position on my guitar, is yours in the bridge?
ethan_hanus
« Reply #2 on: December 17, 2011, 05:54:48 AM »
Thanks, yeah, mine is in the bridge of my Squier Strat, might have to tweak this pedal some so it's not so mid scooped sounding.
Working on it.
Transcend
« Reply #3 on: December 17, 2011, 01:46:45 PM »
Hey,
To fix your reverse taper pot issue you can just wire the pot in reverse and it will increase normally you will just have a bit more range at the beginning of the travel
ethan_hanus
« Reply #4 on: December 21, 2011, 01:50:21 AM »
I think I tried that, and it didn't work...but maybe I just switched the two outside wires, and not the center wire with any of the outside wires. Is that what you are talking about?
Working on it.
Transcend
« Reply #5 on: December 21, 2011, 06:32:30 AM »
You just need to switch the two outside wires, that is unless the centre lug is also connected to one of the outside ones then it still connects to the centre but to the opposite outer lug too
Chargrilled
« Reply #6 on: January 02, 2012, 06:56:00 PM »
Sounds wicked!!
You can just never quite get the same sound as an amp with a simulator.
I had a problem getting a thick sound on amp sims on my PC but was advised to play the guitar part 2 or three times as opposed to just copying the same recording onto different tracks. Still don't sound as good as this though  :D
