Author Topic: Talk to me about the A-pig in a basswood Ibanez RG.  (Read 5930 times)
shred-o-holic
« on: December 21, 2011, 08:16:32 AM »
I did go with the C-bomb but so far while it is super tight and does have a unique voice.......I find it a little "2D" sounding. I had a Duncan Custom in it earlier and to tell you the truth it sounded better to me. The feel was a little looser but the guitar had more balls and was more expressive. Given the tight nature of BKP's is the A-pig still tighter than the Duncan?  I like the Alnico sound in actives so perhaps I would in the A-pig??
« Last Edit: December 21, 2011, 08:20:09 AM by shred-o-holic »
shred-o-holic
Re: Talk to me about the A-pig in a basswood Ibanez RG.
« Reply #1 on: December 21, 2011, 08:19:43 AM »
And I like the supercharged attack of actives so maybe the A-pig could do some of that? I hated the Pain Killer.....and to me the C-Bomb is somewhat similar to the MM I used to have.
Madsakre
« Reply #2 on: December 21, 2011, 08:24:11 AM »
I use an Apig in my RG7321. Sounds decent, but theres not that much attack in the sound. The Cpig does that job a little better
Cattlepress
shred-o-holic
« Reply #3 on: December 21, 2011, 08:27:02 AM »
Does it have any tightness. I see you prefer the PK which I don't so maybe for me it might work? I don't like bright screamy pickups....
Madsakre
« Reply #4 on: December 21, 2011, 08:47:52 AM »
it has enough tightness for pretty much anything, if you need to tighten it up a bit more, then boost it with a tube screamer.
I have a couple of clips here:
http://bareknucklepickups.co.uk/forum/index.php?topic=26235.0
Cattlepress
shred-o-holic
« Reply #5 on: December 21, 2011, 05:56:36 PM »
I have an Axe-FX and can dial any tightness I need really. I do like the C-pig better in your clips thanks.
Madsakre
« Reply #6 on: December 21, 2011, 07:44:28 PM »
good choice
Cattlepress
« Reply #7 on: December 22, 2011, 04:06:19 AM »
did you try the alnico nailbomb?
shred-o-holic
« Reply #8 on: December 22, 2011, 07:04:30 AM »
That's another consideration. I gotta say though I haven't been impressed with the low end of the MM, PK, and C-bomb thus far. I keep reading these impressions about the great low end of BKP's.....haven't heard it in person yet.....to me so far the BKP's I've tried lack low end. So when I read about Warpigs having too much bottom end.....I think for me they may be just enough.....
« Reply #9 on: December 22, 2011, 01:27:24 PM »
When you say the Miracle Man lacked low end for you then the Alnico Nailbomb is out - it has less low end. I agreee that the Warpig is then the only BKP left which could possibly do what you want.
Never played a Duncan Custom but the general comment on these seems to be that it is a very midscooped pickup. If that is true, a heavy midscoop can make it appear to have a lot of low end.
Indeed - all BKPs I played so far are very tight in the low end - which is why I like them. The low end to me is the least important part of the guitar sound (that's why you have bass players in the band :)).
shred-o-holic
« Reply #10 on: December 23, 2011, 12:34:43 AM »
It's hard to explain I guess. I just need more fullness and power in the low end than what I have experienced so far. So yeah the Warpig is pretty much last on my list to try.  And trust me this also has to do with the weaker sounding tonewood in the RG Prestige. I wouldn't be so interested in powerful lows with some of my heavier guitars. They already provide their own kick respectively......
« Last Edit: December 23, 2011, 12:52:08 AM by shred-o-holic »
shred-o-holic
« Reply #11 on: December 23, 2011, 12:42:05 AM »
I like what this guy has going on with his C-pig:
http://www.youtube.com/watch?v=OahYks4tz_U
Ironically I own a BRJ Hesperian 6 so I kind of know that makeup/sound/feel of his guitar. Very helpful that video.....
« Last Edit: December 23, 2011, 12:47:36 AM by shred-o-holic »
Madsakre
« Reply #12 on: December 23, 2011, 06:55:51 AM »
thats an awesome guitar!!!
GAS, even though its xmass
Cattlepress
Loomer
« Reply #13 on: December 23, 2011, 10:31:39 AM »
I've always thought that in bright piece of wood, the A-pig sounds plenty tight. I have one in my beloved Tele, and it sounds perfect. But since basswood is slightly more "neutral" sounding wood, my gut feeling tells me the C-pig might be a tad better.
« Reply #14 on: December 23, 2011, 10:56:02 AM »
pickup height affects a lot the low end
I had my riff raff in a prs for a while, and couldn't set it low cause the screws were short
it was bassy as $%&# close to the strings
