New 2nd had power amp
Started by roland_rat, December 26, 2011, 07:42:45 PM
roland_rat
Hi picked up a ebay purchase today.  A marshall 9100 power amp.  Basically 2 50 watt power amps in one box.  Just tried it and am very happy.
Frank
lovely power amp, got one myself off ebay with a set of Winged =C= in it for £250
I'd take that over the 100 Watt a side version, use it at 50 Watts for smaller gigs or both sides of the amp if you're playing a stadium.
roland_rat
Frank I do not think the stadium tour is happening any time soon. lol! So I too will just to using one side of the amp too.  Mine unfortunatly was not has cheaph as yours. It cost me £300 but I am very happy with it for that price.
Frank
£300 is still a great price and as long as you don't mind lugging that huge weight round it's a terrific piece of kit. If you've got any christmas money left then Winged C tubes will make it sing and growl. And if you're feeling adventurous you could fit 6L6 tubes in one half (need to tweak the bias!) for a bit of tonal variation.
roland_rat
Frank to be honest I have not looked what valves are in it at the moment. I like the idea of having 2 different types in there.
Orpheus
Nice one! I purchased the earlier version of that beast: the 9005.  It's a lot of fun, and really addictive to play in stereo. Plus it makes it really easy for a buddy to bring a pod over or something and jam. I like to run JJ EL-34s i one channel and the big bottle 6CA7s in the other.
Gareth - your amp is fitted with an unusual tube that is labelled as a 5881 but it is not the old style 5881 but rather a russian variation that Marshall were able to get hold of when EL34s went a bit scarce.
I have exactly the same amp and it sounds really good - somewhere between 6L6 and EL34
d1dsj
Cool amp mate, should have kept mine. What are you going to run through it?
Frank
If it uses 5881 tubes instead of EL34 ... you could get yourself a lifetime supply of replacements
Quote from: Frank on January 26, 2012, 10:24:53 PM
Those are the ones......
jpfamps
#11
If it uses 5881s, from what I remember you have to use the Russian "button base" variety as others are too tall to fit in the chassis.
I would check this before you buy any replacements.
