Hum...until I touch the bridge or strings
Started by Wombatman, January 31, 2006, 08:45:30 PM
Wombatman
Long story short, I have MM pickups and love them. The guitar hums until I touch the strings or the bridge. Not a huge deal, I just wanted to determine if the strings are properly grounded.
From what I read, if the noise DECREASES when you touch a metal part on the guitar, that means that you are acting as an additional ground to the already grounded strings. Is this correct or incorrect?
It's not REALLY loud, it's just something I noticed. Thanks!
Steve-Mr Pig 2U
Its a common misunderstanding that the player is grounding the guitar. If you think about it, when do you ever play bare foot?
Humans act like massive antenna and pickup alot of air born RF, the ground wire in your guitar is there to ground you out too.
It sounds like an earthing problem, go over the connections and make shure all parts are grounded.
 Glad you like the pickups!
HJM
The noise decreases as Steve says because you are now grounded through the guitar, so you become a shield rather than an antenna!
So you're extra shielding rather than extra grounding.  I'd guess the grounding is fine and you're in a hot RFI area......but check it anyway!
Searcher
Quote from: Steve-Mr Pig 2Uwhen do you ever play bare foot?
About half the time.  :)
Wombatman
Thanks for the replies...is it also possible it could be a pickup switch problem?
A friend of mine had this happen in his Les Paul and they checked everything to no avail. The shop that fixed it claimed it was the pickup switch.
The guy who put these in really knows what he's doing, so I'd be surprised if they're not properly grounded...anything is possible though.
HJM
It could be, perhaps.....I'd guess it's all OK and it's just high RFI. I get the problem in some places and not others - just one of those guitar things!!
