Author Topic: esp eclipse II pickup choice?  (Read 5652 times)
mniel8195
Re: esp eclipse II pickup choice?
« Reply #15 on: January 17, 2012, 12:32:47 AM »
On my guitar I could almost flip the pickup ring around but the the slated upside would be facing the strings so when I fret higher on the neck the strings may buzz on the plastic ring.  I would prefer it to be parralell to the strings like my bridge is.  I'll look into once I get my pickups.
FRockStar
« Reply #16 on: January 17, 2012, 01:24:29 PM »
A twist with sturdy pair of plyers to adjust the angle of the pickup legs where the screws go thru (the feet, as it were) did the trick on my SG. Ihad to file down the scratch plate a bit, as I recall. So, you may need to file down parts of the pickup ring to allow the pup thru at the right angle? I've only tried it on my SG which has no rings.
Play it like you stole it!
