Quote from: mniel8195 on January 16, 2012, 10:19:13 PM
Pulled the the trigger on a rebell yell vhii neck combo in zebras for the eclipse. If for some reason it doesn't Work I'll go the nailbomb route. How long does it take to ship to Seattle? Got three new 550 pots just going to wire it up pretty standard for now. Do I need new capacitors if I'm running off of emg wiring?
Don´t forget that you will need to tweak the height of the PUs a lot. And I mean a lot. You will be suprised how sensitive they are to height adjustments (I can speak for the RY bridge in the combo you ordered). Took me a long time to get is somewhat right.
Start very close to the strings and slowly (and I mean half a screw turn can make a lot of difference slowly) back up.
Get used to how the characteristics differer.
Then slowly zoom in on what works best for you. (I personally like the PUs backed up quite a bit, like 4-5mm far away even)
This will take quite some time (if you do it properly about a month I´d say) but believe me, it will be worth it!
The RY is incredible.
Just don´t dismiss them right away if you are not 100% happy with the initial sound. Take 1 or 2 turns of the screw and listen again and you will understand
