Quote from: ninetta82 on January 09, 2012, 12:48:17 PM
by sample nilebomb (alnico) is very good for me.
in case what pick-up for the neck?
Welcome to the forum! I would go with a Nailbomb Alnico V model for sure. IT is a great all around pickup for all kinds of rock and metal related stuff. In split coil it sounds pretty good and does have a nice bluesy tone if you mess with the tonen nob and volume a bit. For the bridge you could stick with a matched set, which means get a nailbomb neck. It has great lead neck tones and is a solid pickup. Now this is just good for an introduction to BKP.
You may also want to look into the Rebel Yell. It has an incredible range of applications, a very sweet organic voice, and does well with hard rock/modern metal as well as standard rock, classic rock, and progressive rock. A great matching neck pickup is the VHII. It's one of the best neck pickups BKP makes and sounds amazing for all kinds of rock and metal tones. You have a very versatile set of pickups there.
For single coils you need a medium output single but honestly ask Tim; send him an email. I do not know how to match singles with Humbucker pairs. I've only played the Slow hand, which is a good option or the Trilogy Sweet, which may be too hot. Someone with a better knowledge of single coil matching should answer; or email Tim Mills as I said. Good luck!
