Author Topic: What do I need?  (Read 5325 times)
andrew11
What do I need?
« on: January 16, 2012, 06:34:14 PM »
So i have had my warpigs in my guitar for a couple years now and love them. But as I grow as a guitarist my taste changes so i would like to coil tap both pickups for some nice single coil sounds.
My question to you guys what I need to achieve this? The guitar is a USA Jackson Soloist, 1 vol (500K) and 1 ton (250K). I would like to have 1 push pull to split both pickups and use the pickup selector to choose which pickup to use.
Warpig set (ceramic bridge)
Re: What do I need?
« Reply #1 on: January 16, 2012, 06:44:06 PM »
a standard push pull will do it, it can be one either the volume or tone - just buy the appropriate push/pull
it will look like this - but you will use the other side of the switch for the other pickup - wired exactly the same
(should say how to wire a coil split on the diagram)
except with BKP colours it will be green/white to the middle lug of the switch, red to switch or pot and black to ground
the alternative is to have 2x push/pulls both wired exactly as above or wired series/parallel.   this will let you get the mixed humbucker/single coil settings
« Last Edit: January 16, 2012, 06:46:12 PM by WezV »
andrew11
Re: What do I need?
« Reply #2 on: January 16, 2012, 07:20:14 PM »
Thanks so much for the info, so just to clarify if i want to use the tone to split I will just buy the BKP 250K push-pull pot and a tech (as I won't be doing this myself) can wire it up as I decribed above?
Re: What do I need?
« Reply #3 on: January 16, 2012, 09:21:26 PM »
yeah
i keep forgetting that the main site now has much better wiring diagrams
its basically this one - except you want the switch on the tone not the volume
http://www.bareknucklepickups.co.uk/main/downloads/schematics/general/humbuckers/2_hum__4con_1_push_pull_vol_coilsplit__1_tone__3_way_toggle.pdf
print it, give it to the tech and tell him the bits you want to change
