Actually, In the case of amps that are hand built at least, it takes pretty much the same amount of time and effort to build a 1watt head than i does to build a 100watt heads.
The JTM1 has a 12AU7 as it's output valve, which could be running single ended or in push-pull. If remember right the 12AU7's when used as an output valve need an output transformer with a pretty high impedance primary. Maybe you're probably paying towards development as well as a new batch of transformers? Maybe even new tooling needed to produce them?
