Author Topic: Gigging an ES330 (Peerless Songbird)  (Read 10838 times)
tomjackson
« on: January 22, 2012, 06:00:53 PM »
It's not pretty but it works!
Re: Gigging an ES330 (Peerless Songbird)
« Reply #1 on: January 22, 2012, 06:04:23 PM »
I like it, sweet guitar, just the chrome covers don't do it quite do it for me. I would prefer black covers on this one.
« Reply #2 on: January 22, 2012, 06:15:47 PM »
Ghetto gigging!
DoomBuggi
  • Insane Person
« Reply #3 on: January 22, 2012, 07:16:10 PM »
Is this for the purpose of feedback elimination?
tomjackson
« Reply #4 on: January 22, 2012, 07:37:26 PM »
Yes, it still feeds back but is just about controlable with the tape.
shobet
  • Look into my eye...
    • http://www.dusksky.com
« Reply #5 on: January 22, 2012, 07:50:12 PM »
Does filling it with rags work?
tomjackson
« Reply #6 on: January 22, 2012, 10:10:44 PM »
Im sure it would but they would probably get stuck.  I wouldn't normally use this guitar at loud venues so just needed to use it as a one off while my tele is set up for slide and my strat in bits.  If I was going to gig it more i'd ram it full of towels but i like the hollowness of it playing at home so just use masking tape to get the gig done.
Expanding foam did cross my mind; fortunately my mind was sober at the time :D
« Reply #7 on: January 22, 2012, 10:37:34 PM »
Maybe you can cut some foam in an F-hole shape and make it black. Anyway, when it works, it works. It does look rock'n'roll this way.
« Reply #8 on: January 23, 2012, 10:55:15 AM »
There are better ways to reduce feedback.
Use less gain;
get a longer cord;
don't face the amp, keep it behind you and if possible keep some distance;
good quality, wax potted pickups.
tomjackson
« Reply #9 on: January 23, 2012, 04:46:59 PM »
Yes I think you can buy things like this. But tape is cooler!
tomjackson
« Reply #10 on: January 23, 2012, 04:52:46 PM »
Use less gain;
get a longer cord;
I didn't use any gain, it's a non MV Princeton Reverb Reissue, on FULL!
No point in that, there was 8 of us and nowehere else I could of stood
See below
The pickups have been rewound by hand and properly potted
The tape is for body feedback as opposed to pickup squeel.  Without the tape it is uncontrolable but with it you can just let the body resonate when you want to.  I did face away from the amp most of the time but occationally I turned round so the guitar was about a foot from the front of the amp and just let it howl whilst holding the chords, it sounds very musical.
Ultimately, I'll go back to a Tele and use some pedal gain but it was nice to use a hollow body straight into the amp, but the tape is a must!
« Reply #11 on: January 23, 2012, 05:08:02 PM »
I can understand stuffing the body with rags/foam/cotton wool would "deaden" the guitar, but I'm surprised something as simple as taping over the f-holes would make such a difference.
I suppose it's like the difference between a BB King Lucille and an ES-335.
« Reply #12 on: January 24, 2012, 11:06:25 AM »
Ah, wait a minute I get it.
I was under the impression it was a semi with a center block but it is a full hollow body.
Could be it doesn't have sound posts. Sound posts connect the top and back of the guitar. Body feedback occurs when the top and back vibrate out of sync. Connecting them together with sound posts keeps them vibrating in sync, which prevents feedback.
Example of sound posts:
My 6120 has the even heavier trestle bracing that looks like this:
tomjackson
« Reply #13 on: January 24, 2012, 01:19:40 PM »
It's funny but even when I had my 335 I used to get feedback out of the f hole, you get a kind of puff of air/vibration on your arm when things get really loud.  I remember jumping the first time I felt it.
A you would imagine, a hollow body is miles worse, I think the tape just seals the air chamber which must damp it enough to take the edge of the body howl.  Either way it does help.
Ratrod, it does have small sound posts, I think it would be even worse without them and I can imagine a vintage ES330 would be a nightmare at the same volume.  But it was loud, only a 15 watt amp but it was on 10 and I was about 3ft away from it....
« Reply #14 on: January 24, 2012, 02:14:58 PM »
Thanks, I'll be prepared now should I ever get the opportunity to crank my 336.  :D
