November 20, 2026, 10:58:55 PM
Main Menu
Main Menu
Home
Search
Bare Knuckle Pickups Forum
Forum Ringside
Tech
fitting a tapped p-90 without fitting the tap?
Started by sambo, February 02, 2006, 05:55:54 PM
Previous topic
Next topic
Print
Go Down
Pages
1
User actions
sambo
Welterweight
Logged
is it ok to fit a tapped p-90 without actually wiring the tap so i can use it until i buy a push/pull pot..?
Welterweight
Logged
#1
February 02, 2006, 07:18:54 PM
Yes, just decide which sound you want (probably the full output), and insulate the tap wire.
sambo
Welterweight
Logged
#2
February 02, 2006, 10:03:35 PM
ok thanks phil. ive done that now but how exactly do you choose which sound you want then????
Welterweight
Logged
#3
February 03, 2006, 12:59:08 PM
You have to try both. You can take the wire out through the jack socket before you solder it, and try wiring each. See which works best for you.
sambo
Welterweight
Logged
#4
February 03, 2006, 09:12:02 PM
ok thanks mate.
Print
Go Up
Pages
1
User actions
Forum Ringside
Tech
User actions
Print
