Author Topic: i ordered 50mm and my bridge spacing is 52.5...will it work?  (Read 7552 times)
mniel8195
« on: January 27, 2012, 06:43:45 AM »
hey guys im figuring out more as i go.  I had no idea the string spacing on my esp eclipse is 52.5 and the bridge pickup i ordered is 50mm. for some reason i just figured it was 50.  Should i return the pickup and get a 53 or does it make a huge difference in tone and interaction with the string?
Re: i ordered 50mm and my bridge spacing is 52.5...will it work?
« Reply #1 on: January 27, 2012, 08:09:35 AM »
You'll be fine.  Only swap it if it bothers you.
mniel8195
« Reply #2 on: January 27, 2012, 08:43:57 AM »
you the man! my soldering is pretty sketchy since i have shaky hand but it should work
« Reply #3 on: January 27, 2012, 08:47:53 AM »
Just take your time and don't do it on Friday if you need it for the gig on Saturday.
Venemous
« Reply #4 on: February 01, 2012, 09:11:53 PM »
It won't make any difference in the sound that you'd be able to notice. It's just mostly cosmetic as other users have pointed out :)
Jackson DKMG - WARPIGS :twisted:
Mikegblues
« Reply #5 on: June 27, 2012, 11:41:49 PM »
Should be ok.  My PRS SE has 52mm spacing on the bridge pup and the 50mm Mule looks just fine.  Strings will most likely still pass over the pole pieces - maybe just on the edges.  Cosmetic only.
« Reply #6 on: July 04, 2012, 05:32:51 PM »
you can also sand the saddles to align strings with the pickup
I do that in some of my les pauls
and that's what gibson does... the strings aren't in the exact middle of the saddles, but they align with the stock pickups
