Splitting a mule neck
Started by Roboten, February 01, 2012, 10:24:55 AM
Roboten
Does a mule neck have a good split sound, or should i consider a hotter pickup for better coil splitting?
Stormy Mondays, Mules, Riff Raffs, '63 Veneer Board Set, BG52s, Emeralds, C-Pig(b), Trilogy(n)
I haven't tried to Mule, but I think that it has been stated before that it splits well. I have a Stormy Monday bridge in a strat and I find the split tones pleasing.
I only use an autosplit which is IT middle + the outer coil of a mule neck (the slug coil) and this works very nicely for clean tones, gives them a tele esque vibe.
BigB
You may also want to consider the serie/parallel option instead of split - parellel coils give a lighter (and lower output), more single-coilish tone than the stock serie wiring while retaining the humbucking effect (for the record, the intermediate positions on a Tele or Strat are actually "2 coils parallel").
I've never tried splitting a BKP, but on all other 'buckers I tried the parallel option sounded way better than the split, regardless of the pup's output.
Brow
I split the Abraxas neck (essentially a Mule neck) in my CU22 and it works well.
Never played a Mule but I
- split the Holydiver bridge and the Cold Sweat neck in my PRS Custom
- the Miracle Man bridge in my alder strat and
- the Abraxas bridge in a HSS set up.
All work well split but with the exception of the Cold Sweat neck are much higher DC resistance pickups.
DoomBuggi
I found the title of this post quite amusing.
BigB
Quote from: DoomBuggi on February 01, 2012, 04:02:08 PM
Now that you mention it...  :lol:
DoomBuggi
Quote from: BigB on February 01, 2012, 09:17:17 PM
I'm also surprised that no one beat me to it as well.  :mrgreen:
The splitted sounds of my Crawler and VHII are very nice.
