1991 Telecaster Plus upgrade
Started by ClassicRKR, February 13, 2012, 03:45:28 AM
ClassicRKR
So, I have been considering replacing the pups on my Telecaster Plus. The Lace Sensors aren't bad, but I prefer something a little more vintage. I was thinking about maybe a Mother's Milk in the neck and a Mississippi Queen in the bridge. Thoughts? I'm worried that it may be a little too bright in the bridge with the MQ because of the body (Ash or Alder, I can never remember) so I was also considering the Manhattan, but I am looking for a really classic rock tone.
I think the Manhattan might be to polite for you as it is mostly aimed at jazzers. If you're not totally set on a P90 bridge you could go for a Mule and Mothers Milk combo which should be perfect for some classic rock. You could also considder a Stormy Monday and Apache combo, but I think the Mule and Mothers Milk will be great.
ClassicRKR
Thanks for the input, but yes, I'm completely set on a P90 bridge, I've loved pretty much every guitar I've played with a proper set of P90's in it.
I think that the MQ bridge have been used in strats before which often has alder or ash bodies. I actually remember an article from Guitarist magazine where 4 of their writers each were given a Yamaha Pacifica to mod. The article was called "Pimp my Pacifica" and one of the writers went for MQ bridge along with middle and neck Mothers Milk as he wanted a blues master strat. The Paifica model has a rosewood board though and I take it that your tele has a maple board.
Anyways I think the combination will work and you can always roll the tone a tad back and take a little of the highs. It's been stated at the forums that a quality pot and a good PIO capacitor can work wonders tone wise and make your tone control much more usable. I haven't tried a PIO capacitor so I can't comment on this.
BigB
Quote from: Mr. Air on February 13, 2012, 06:54:28 PM
Any decent capacitor (by which I mean "appropriate for audio signal filtering use") will be an obvious improvement wrt/ the cr@ppy ceramic ones that come stock on 99.9% of today's guitars. I personnaly like PIO caps quite a bit for the "warming" effect they can have on tone but there are other options.
P90 in the bridge works great with tele's. And there is the toneknob too. If you have a rosewood fretboard the MM will be fine, if it's maple it might be on the bright side. An Apache would be a good alternative.
ClassicRKR
Yes, my Tele actually has a rosewood board. Thanks for the input guys! I'll be looking into getting them asap!
I'm looking foreward to hearing your reaction once you get the pups installed. And the "rule" here at the forums is - pics or it didn't happen  :D
ClassicRKR
Well it may be a little bit, gotta see how my taxes turn out  :D I'm just a planner/dreamer, but if it works out to where I get the money then you will be getting pics asap!
