Author Topic: Humbucker tone difference when wired hot-ground or ground-hot?  (Read 1901 times)
« on: February 21, 2012, 03:57:08 PM »
I'm guessing the answer is "no difference" but I thought I'd ask anyway.
The usual BKP wiring for a 4-conductor humbucker is:
* Black/earth to ground
* Green/white together and taped off
* Red to hot
Would it make any tonal difference to flip them to:
* Red to ground
* Black/earth to hot
I know if you want to use the splits then this would give you the screw coil instead of the slug, but without splits I'm guessing there's no tone difference?
WhiteRam
Re: Humbucker tone difference when wired hot-ground or ground-hot?
« Reply #1 on: February 21, 2012, 05:28:06 PM »
I was on the phone with Ben at BKP about 4 weeks ago concerning some things and I asked him that question for knowledge reference (I put the question to him as would there be any "sonic" difference with the humbucker in series) his reply... no difference. 8)
I should add that I have never personally tried it. Rock on :)
« Last Edit: February 21, 2012, 05:31:15 PM by WhiteRam »
We reject as false...their definition of what our ideals, preferences and standards should be.
« Reply #2 on: February 21, 2012, 06:16:08 PM »
I suppose another question might be whether it makes any difference to wire this way:
* Green (or White) to ground
* Red/Black together and taped off
* White (or Green) to hot
That way you're sort of "inverting" the wiring and using the inner ends of the coils rather than the outer ones (although I'm not sure which is which).
I suspect the answer's the same - no difference, or not enough to notice.
« Reply #3 on: February 21, 2012, 07:02:49 PM »
Didn't think so!  Just thought I'd ask...
« Reply #4 on: February 22, 2012, 10:10:40 AM »
Whenever I had an out-of-phase switch in a guitar the switch did not change the tone with only a single pickup selected. Of course there was a lot of change when both pickups were selected.
