is it worthwhile fitting bkp pg pickups in psr se single cut guitar
Started by stewart, March 08, 2012, 06:50:29 PM
stewart
This may be a naive question but I do not have a great deal of knowledge in relation to guitars.  I have just bought a prs single cut se and was wanting to fit the bkp peter green pick ups on it.  However the pick ups will cost almost exactly what I paid for the guitar.  Do other forum users think this will this be a worthwhile use of my money.  I could save up and buy a more expensive guitar but really like the prs.  It would be sometime before I could buy a more expensive guitar in any event. Any thoughts or advice really appreciated
Lezard
That's by no means a bad guitar, and a set of BK's will improve anything that isn't total rubbish.
And you can always transfer the pick-ups to another guitar if you do get something high end.
Btw the PG pick-ups have a pretty unique tone due to them being wound out of phase with one another. If that's the tone that you're after then it's definitely worth it.
but If you want something more conventional I'd look at the Stormy mondays or Mules (or even one of each)
Gizmo
If you are new to guitar you may have a basic amp. What amp do you have? You may find you get more noticable improvement in sound from a better amp.
Secondly if you are new to guitar you might not know what is the best guitar for you so would be worth sticking with and learning what suits you. The PRS single cut SE is a v good guitar and a v good choice imo.
Comparing the equivalent pickup in the BKP range to the ones in your SE, you would notice an improvement. Comparing the PG Blues to the pickups you have you will notice a massive change just because they are quite different pickups to start with. The PG Blues are low output pickups so will sound quite different. They are very good low output PAF sounding pickups.
A good mid range guitar like an SE + pickup grade can sound very good. Its deminishing returns when your then upgrade the guitar past a certain point in terms of sound. Of course there is aesthetics and prestige and other things which make people want high end guitars but you'll be happy with that combination. What music/artist is it you like?
BigB
I can only second Gizmo here.
To answer your question: midrange guitars often have a decent lutherie and half-decent (et best) pickups / electronic / gear, so if you like the guitar itself (playability, unplugged tone, reactivity, character etc) but find the amplified tone a bit lacking then upgrading the pickups and electronic can really pay off - my experience -, but this imply you have 1/ a decent amp and 2/ enough experience with guitars to know what you like and dislike.
Matt77
Agree with all the above
Worth it.
Just keep the old ones so you can put them back in if you sell the guitar.
Bareknuckles have a good resale value as well
Quote from: Matt77 on March 08, 2012, 08:37:33 PM
Worth it.
I agree with all that!
Quote from: Philly Q on March 08, 2012, 11:47:17 PM
Worth it.
Me too. The stockpickups in the PRS SE Singlecut are decent, but BKP's are quite a step up. But a good amp is essential to get a good guitarsound. Especially with lower outpickups a nice tubeamp is the icing on the cake. By example: the Mother's Milk in my strat sound ok through my Blues Junior, but amazing through my Orange Rockerverb.
Quote from: stewart on March 08, 2012, 06:50:29 PM
order the PG Blues set with 4 conductor wiring
That way you can choose whether to have the two pickups in phase or not- depending which way you wire them
You could have a phase reversal on a push pull tone pot - or maybe use that for coil tapping instead
Loomer
Go for it!
The almost comically stringent PRS quality control luckily carries over to the SE range as well, so with a good setup job and some bkp's you'll have a guitar that can outperform pretty much anything, methinks.
Quote from: Loomer on March 09, 2012, 11:59:21 AM
Not quite, but I see what you're saying  ;)
The PRS SEs I have seen were more than just decent guitars. You could do much worse than those. If you like the guitar and feel comfortable playing it then go for it. Just make sure that you know what you want and then ask Tim what is the best fit for that.
Loomer
Quote from: Twinfan on March 09, 2012, 12:06:49 PM
Well, at least in that price range in any case :p
I can sort of imagine they won't have much on the Private Stock models.
Madsakre
Quote from: Loomer on March 12, 2012, 01:57:57 PM
You mean Private Suck?
Cattlepress
witeter
I have a PRS SE Custom 24 which i upgraded to a CBomb set + new pots +caps and a PRS SE Tremonti which has a CS set +new pots + caps - if you wanna stay with these gtrs you probably would be looking to upgrade tuners/nut further down the line. But for their price there are very few guitars better than the PRS SE line-so go for it! :-)
[url="http://www.facebook.com/flailhead"]http://www.facebook.com/flailhead[/url]
[url="http://www.facebook.com/insunaband"]http://www.facebook.com/insunaband[/url]
[url="http://www.sabreguitars.co.uk"]http://www.sabreguitars.co.uk[/url]
Sabre Custom Wraith
Ibanez RGA42
asianaxeman
anything to improve the awful SE range is worth a try but if I were you save up for another guitar. My experience with SE was bad, noisy pickups which fed back like crazy, cheap fragile neck and headstock, useless tuners, noisy cheap pots, werid scale length, bad low quality paintjob and finish which declared itself after minimal use, and God awful fixed bridge one is unable to intonate. Good luck.
