Author Topic: rebell yell vhii ballance question  (Read 1479 times)
mniel8195
« on: March 08, 2012, 08:14:59 PM »
hey guys...I was was wondering if anyone has this setup.  I have the bridge set pretty well around 2mm from the strings depressed at the last fret. But im having a hard time getting the vhII to sound ballanced with it.  Any suggestions on where i should start on the height? 4mm??? then tweak fromt there?
Re: rebell yell vhii ballance question
« Reply #1 on: March 09, 2012, 08:27:51 AM »
Are you talking about volume balance? And which one is louder?
If the neck pickup is too loud I would move the bridge pickup a bit closer to the strings - 2mm with the string depressed on the last fret is not really close.
4mm on the neck pickup looks good as a starting point.
Good luck,
Stephan
