Quote from: PartyAnimal223 on March 10, 2012, 08:51:09 PM
Quote from: BigB on March 10, 2012, 08:27:54 PM
Quote from: itsonlyausername on March 09, 2012, 06:07:49 PM
Epiphone les paul Specail II GT mohagony body and neck rosewood fret board.
Huh ??? Are you sure it's a mahogany body ???
FWIW, I happen to own one (swapped it for a marshall GVII pedal I was not using, nuff said), and it's actually plywood body. I've heard there were some versions made with plain wood so double-check what you actually have before you spend your good money on good pickups. The one I have is a decent entry-level beginner guitar and better than what I expected for the price (35€ :xD), but it doesn't deserve any upgrade, seriously (and I'm definitly not into fancy expensive guitars).
My 2 cents...
This was my first guitar also, I would recommend getting a real guitar, the one I have is horrible sounding, I thought it was basswood or something, regardless its not "good" mahogany and it did not come from where gibson gets their stuff. I think you should find a PRS SE singlecut model of some sort, better neck, quality, sound, and look.
You should look into getting a boost pedal, I didn't like tubescreamers like the ts9 or od808 because they cut to much low end and the guitar sound wasn't as full, with the maxon od9+ pro my sound is tight and balanced sounding and much clearer.
ugh i thought this would happen
The Epiphone specail GT is not the epiphone specail go on the wibesite the spec or as follows
Body:
•Body Material: Mahogany
•Bridge: 6-Screw Vintage-style Tremolo
•Colour: Worn Black (WK)
Neck:
•Neck Materials: Hard Maple
•Neck Shape: SlimTaper
•Neck Joint: Bolt-On; Contoured heel with recessed 4-bolt pattern
•Truss Rod: Adjustable
•Scale Length: 24.75"
•Fingerboard Material: Rosewood with pearloid Parallelogram inlays
•Fingerboard Radius: 14inch
•Frets: 22 medium-jumbo
•Nut Width: 1-11/16"
Pickups & Hardware:
•Bridge Pickup: U.S.A Designed 700T? Humbucker
•Neck Pickup: U.S.A Designed 650R? Humbucker
•Controls: Master Volume Master Tone with integrated push/push Kill Switch - 3-way Toggle
•Hardware: Black
•Machine Heads: Premium, 14:1 covered
This was epiphone essentailly making a cheap guitar better and mind happen's to be the best the mahagony is solid that even a skrew driver couldn't dent it i remember an art teacher telling me you know it real mahagony when you can't drive a nail through it.
It maybe sourced cheaply and many rule's are violated but that dosen't go to say one in 1000 can't turn out to be perfect.
My bridge humbucker is also broken so i need a replace and i don't have the money for another guitar however i have got my eye on my next buy it's nothing specific rather a project of impulse and maybe il take the bridge pick up out and put it in that if i so desire.
Also bolt on and set in theoritically are on the same level and has been argued many time's over. While with a bolt on you have metal absorbing the sound waves that resonate with the body in a set in there is still a gap and between the gap there is glue which only goes to slow down the sound waves/vibration from crossing neck to body on top of that if you have ever did wood work in your life alot of skill is needed to make a wood joint and sometime's it can be to thight making unreliable understress are too loose and to get perfect is near damn impossible unless your a robot that has been made 1000 years into the future it will alway be a little to too thight to a little to too loose to keep quality is impossible even for gibson. But with bolt on what can go wrong? and if a set neck breaks what do you do?
Please refrain from comments against the guitar in it's price range it is the best and most likely better then guitar that cost more then it.
and it is a real guitar.
