Author Topic: Ibanez 1820x HH wiring  (Read 13004 times)
Lederstrumpf
« on: March 10, 2012, 11:59:38 AM »
Greetings,
I recently bought a pair of Nailbombs to replace the V7 & V8 stock pickups.
This wiring diagram illustrates the previous configuration:
http://imageshack.us/f/697/23382388.png/
I am uncertain whether I installed the Nailbombs correctly.
After soldering black and bare to gorund, I soldered the green and white wires where the red ibanez ones used to be.
The bridge pickup seems to work correctly, but the neck pickup is very thin.
I also soldered the red wires to the positions where the white Ibanez wires used to be; the bridge split sounds very weak and the neck split is not distinguishable from the neck humbucker mode.
I'll switch the black & red bridge wires to solve the bridge split issue, but I'm uncertain concerning the neck pickup since the green & white wires are seemingly connected correctly.
Re: Ibanez 1820x HH wiring
« Reply #1 on: March 10, 2012, 12:57:02 PM »
For this wiring to work properly you need to reverse the magnetic polarity of one of the pickups!!
I don't know why that fact isn't more widely acknowledged at BKP
Lederstrumpf
« Reply #2 on: March 10, 2012, 01:05:38 PM »
What a tool I was! BKP actually has a wiring diagram for this setup, I just did not find it in the list because it is listed in-between the Braided-2-Con diagrams ^^
Lederstrumpf
« Reply #3 on: March 10, 2012, 02:23:06 PM »
Now I cannot hear the neck pickup anymore at all :(
Toe-Knee
    • DIY Audio
« Reply #4 on: March 10, 2012, 02:25:56 PM »
As Feline said you need to get the magnet in the neck pickup reversed otherwise it wont work correctly.
http://WWW.BACKLINE.TK
Non Biased Guitar Forum
http://fret.boards.net
Lederstrumpf
« Reply #5 on: March 10, 2012, 02:38:32 PM »
Wait, I physically have to open the neck pickup and turn around the magnet?
Toe-Knee
    • DIY Audio
« Reply #6 on: March 10, 2012, 02:40:38 PM »
Yup this is one thing that you ideally need to add to the notes when ordering.
I would personally send it back to BKP.
If you get in touch and let them know im pretty sure they would happilly sort it out for you.
Lederstrumpf
« Reply #7 on: March 10, 2012, 02:49:13 PM »
I already shortened some wire and cut the edges of the screw holders to make it fit into the rounded extensions of the pickup cavities of my Ibanez; haven't I already voided my warranty?
Toe-Knee
    • DIY Audio
« Reply #8 on: March 10, 2012, 02:50:40 PM »
Im not entirely sure to be honest.
However the warranty is just if the pickup itself is broken.
Swapping the magnet around is an additional thing to this and you may get a small charge but you never know. It's best to email Tim and see.
Lederstrumpf
« Reply #9 on: March 10, 2012, 02:59:06 PM »
I live in South Africa. Shipping and handling would cost around 40 pounds and I'd have to wait in excess of 6 weeks to get them back here (It already took 5 weeks to get here because of customs). I think I'll just take a risk and do it myself. Considering BKP's reputation, I doubt I'll ever have to make use of that warranty anyway.
Toe-Knee
    • DIY Audio
« Reply #10 on: March 10, 2012, 03:11:12 PM »
Make sure that you do your research first.
or alternatively hook them up differently it would save a lot of hassle.
I know how great the ibanez 5 way wiring is though i have it on 2/3 of my guitars and soon it will be 3/3 when i get my next one and sell the 7 string
Lederstrumpf
« Reply #11 on: March 10, 2012, 03:16:25 PM »
After doing some research, I realised that reversing the magnet and wax-potting the pickup again is a lengthy procedure that would require time that my studies currently will not allow. I will attempt this in my vacation.
However, is there an alternative way to hook up my pickups that I could use in the meantime?
« Last Edit: March 10, 2012, 03:43:00 PM by Lederstrumpf »
Toe-Knee
    • DIY Audio
« Reply #12 on: March 10, 2012, 03:40:38 PM »
What alternative way would there be to hook them up?
Would I only be able to use humbucker mode then?
you could just go
Bridge
bridge split
both
neck split
neck
or something like that.
Lederstrumpf
« Reply #13 on: March 10, 2012, 03:58:10 PM »
Hmm, my neck pick still sounds relatively weak in this configuration, despite being closer to the strings than the bridge pickup.
Toe-Knee
    • DIY Audio
« Reply #14 on: March 10, 2012, 04:27:56 PM »
have you tried it just in normal humbucker setting?
