HELP! Humbucker humms! :/
Started by GuitarIv, March 13, 2012, 10:10:56 PM
GuitarIv
Hey folks, I'm new to the forum and decided to sign up since I need some help...
Following Problem: I have a Custom Strat with a HSS configuration, and I had the problem that the hum from the guitar was unbearable. So I went to a Luthier to get the problem solved and he shielded the electronic chamber... which didn't help at all. The hum was still there, comming from the Singlecoils as well as from the HB. When I asked him why the guitar still was humming, he told me that it's a normal issue, since interferences are all around. Well strange thing: I have a Ibanez RG 350MZ (cheap model, made in Indonesia, 2 humbuckers installed) and use it in the same environment like the Strat and it doesn't hum at all. However, I kinda forgot about it and played my RG, with the Strat lying around. A friend of mine gave me recently a used Duncan Jeff Beck and I decided to put it in the Strat. I changed the pickups and soldered the HB like it's done in this diagramm:
http://www.seymourduncan.com/support/wiring-diagrams/schematics.php?schematic=1h_2s_1v_2t_5w_as
Didn't touch the grounding cables or grounding soldering at all, and the guitar works but the hum is still there! And most annyoing: when I switch to the position where the neck and the middle SC are activated together, it cancels the hum.
So: Position 1 (Just Neck Singlecoil) hums like it is supposed to, Position 2 (Neck + Middle SC) doesn't hum, also fine, Position 3 (Middle SC) hums like supposed, Position 4 and 5 hum and they shouldn't. Now I don't know what the problem could be, I suppose the Humbucker is wired to work like a singlecoil or something? I also read something about being out of phase. I really don't know what's wrong and I'd appreciate every help I get, if you need pics, just tell me.
Thanks and cheers
What make and model humbucker and singlecoils are you using?
It sounds like your humbucker is the problem, and may be wired as a singlecoil - what's the output like?
GuitarIv
The Singlecoils are two Duesenberg Vintage, and the Humbucker is a Seymour Duncan Jeff Beck. With Output, do you mean the Sound in general? Because i kinda noticed it sounds thinner than I expected it to do.
Oh and btw, I just read that by switching the hot cable with the ground cable you can remove the out of phase problem, should I try it?
Attica!
Have a check to see if your Bridge is grounded as well. My bridge wasn't grounded on my Les Paul and it would hum. Try taking your knobs off your pots, and tap them to see if the noise gets worse/better.
GuitarIv
Just took of the knops and touched the pots, nothing changed, the hum was the same
Attica!
Well sounds like everythings grounded. Try stuff like touching the pots inside the cavity with your finger and then a screw driver. Touch different parts, aswell as the toggle switch etc. It's best narrowing down the problem first by trying all the simplist, effortless tests.
GuitarIv
I will do so tomorrow, I might as well try to exchange the hot and the ground wires, maybe it's the out of phase issue. I'll post the results then, thanks for the help so far :)
Frank
Quote from: GuitarIv on March 13, 2012, 10:10:56 PM
ok, that threw me for a minute because you're numbering the positions the opposite way round from most people!
From what you're describing, the two single coils are working fine in that they hum cancel when combined. Like Mr Twinfan says, it sounds like your humbucker is only working on one coil and that coil isn't able to hum cancel with the middle pickup.
If the HB has exposed pole pieces then try tapping both rows with a magnetic screwdriver or a key, listen for a thump through the amp and it should be immediately obvious if you've got one dead coil. If only one set of pole pieces thumps then you either have a wiring problem or a broken pickup coil - disconnect the entire pickup and check its DC resistance with a multimeter (assuming you have one).
If you suspect a dead coil, you can be 100% sure by simply connecting the individual coils straight to the jack socket (I just hold them on the tip and ring of a jack plug, quick and easy) and seeing if it picks up any string vibration. With Seymour Duncan pickups one coil is black to white leads and the other is green to red. Those combinations across a multimeter or jack plug will tell you if the pickup's working.
If it is working - check all your wiring and soldering, especially on the backs of volume/tone pots which may have dry solder joints or bad connections. And if your pickup is dead, throw it away and buy a BKP.
GuitarIv
Sorry mate, I'm kinda new to all the pickup stuff and always trying to expand my knowledge, lesson learned :P
As far as the condition of the pickup goes: I'm pretty sure it's fine. I already tapped and scratched with an allen wrench over the polepieces and as far as I could hear it I had sounds on the same noise level. The humming issue was also present with my old Humbucker, a Duesenberg Model. I think (or hope) it's more the grounding problem. Or the "out-of-phase" issue, no one gave me an opinion on that one yet. Should I try to change the hot and the ground wire?
I need to get a multimeter yet, so I'll just change the hot and the ground wire and if that ain't working I'll try to find the weakest link in the grounding chain, as mbchepburn suggested I'll run my finger across the wires and soldered pieces to see if there's anything wrong.
And concerning BKPs: I'm planning to get some anyway, at the moment I'm just kinda broke so I have to go with what I've got ^^
Cheers
Frank
I'll be honest, I don't think it's to do with phase. If you're picking up hum from somewhere then reversing the phase of the pickup will just reverse the phase of the noise voltage and you'd be back to square one!
GuitarIv
Hmm, I see. Well then I'll just check the soldering and I hope I'll find the problem...
Attica!
You may also want to consider your equipment. Have you any pedals? And does the guitar make the same noise in all amps, as well as other guitars being quiet with your amp? On my Bugera 333, I play with it in close vacinity to my guitar and the hum is pretty bad, but gets better the more I move away. But with a Noise Gate, this eliminates that problem.
GuitarIv
Nope, my equipment can't be the problem since my Ibanez doesn't hum at all, the Noise Surpressor doesn't cancel out the hum of the strat even when I'm not playing and as said when both single coils are selected the hum goes away instantly.  :?
Frank
Quote from: GuitarIv on March 14, 2012, 01:19:10 AM
This is what leads me to suspect a non-working coil in the humbucker i.e. it's acting as a single coil pickup and humming!
GuitarIv
Well that would suck... as said I'll try a few things and keep you guys posted... till then I wish you a good night
