Author Topic: Made some progress on a 3yr Tele build!  (Read 6492 times)
Oli
« on: March 27, 2012, 01:47:15 PM »
Not long after I finished my first 3 guitar builds, life took over, and i've not really made any progress on the other projects that I started over 3 years ago!
However, now that it is lovely outside, I thought that i'd head over to my folks' place and get a couple of days work done down  in the workshop. I've had this tele going on for a long time, and it's the guitar that is closest to being finished (and I have most of the hardware, to boot!), so I cracked on and made some progress.
Swamp Ash body, and a lovely maple neck that is slightly flamey (although the fretboard side of the neck does seem quite soft, but i'm hoping it'll be ok and I won't have to do it again). The neck is a 1 piece, with a Walnut headstock plug, and I think that the skunk stripe may have ended up being Mahogany, as I didn't have any appropriately sized Walnut at the time. Lovely 2 piece body which I hope to finish eventually in a translucent blonde finish, although there's a hell of a lot of sanding to be done. It's going to be a very light guitar too, and hopefully nice and twangy :)
Found out that the centre line on my body and cavity templates don't line up, so when I first put the neck on, the strings would have been about 1cm to the left of where they should be... not very happy with that, so if you're thinking of buying templates, do some measurements and check the centrelines!!!
Just going to carve the neck, then let it settle down for a while before I tidy up the frets. Need to bring the neck into work to get the tuner holes drilled too, as I no longer have a pillar drill :(
FredD
Re: Made some progress on a 3yr Tele build!
« Reply #1 on: March 27, 2012, 09:01:41 PM »
Very nice !!  You have certainly been a buzy bee  :lol:
« Reply #2 on: March 27, 2012, 09:37:23 PM »
its a great start! good luck with the rest.
« Reply #3 on: March 27, 2012, 11:03:45 PM »
Looks good already!
(But only three years?  I take longer than that to get round to fitting a set of straplocks....  :roll: :lol: )
« Reply #4 on: March 27, 2012, 11:14:13 PM »
Ah, when you save something, you have something, they say here. Looks great already! Suc6 with the project.
« Reply #5 on: March 28, 2012, 06:56:29 AM »
Looking good :D
« Reply #6 on: March 28, 2012, 07:51:41 AM »
That looks great! My tele build has been going on for well over a year now. I'll be very interested in how you get on with the neck!
roland_rat
« Reply #7 on: March 29, 2012, 01:15:56 PM »
Looking good :D
« Reply #8 on: March 29, 2012, 01:24:26 PM »
I'm starting a support group for that Phil :D
« Reply #9 on: March 29, 2012, 02:19:45 PM »
Will I be the founder (and only) member?
Sifu Ben
« Reply #10 on: March 29, 2012, 07:48:28 PM »
I was going through my gear box to do some wiring, and found a load of straplocks I bought 2+ years ago :o
« Reply #11 on: March 30, 2012, 03:29:42 PM »
No - it will be a good thing :
Here is the link to the page :
https://bareknucklepickups.co.uk/forum/index.php?topic=27282.0
