Were Rebel Yell pickups r&d'd as a Covered pickup?
Started by ZeroFiveFour, April 02, 2012, 06:10:00 AM
ZeroFiveFour
I have recently ordered a set of Rebel Yells.
Due to the Ray Gun covers offered with the Rebel Yell pickup as well as having seen a few youtube videos of Steve Stevens playing the signature pickups with Ray Gun covers in his les paul...
I was wondering if the pickups were designed as a "covered" pickup or not.  Also... is it possible to remove a cover easily if one wanted to do so?
Any info is appreciated.
Cheers,
Tom
monkey8911
Hey Tom, its really easy to remove covers from Humbuckers, I do that quite often, since I only have one pair of aged covers. (did the aging myself too :-))
http://www.youtube.com/watch?v=5uBXid7Eq4A here is a good video.
What I doo additionally is potting the cover so it won´t get microphonic. First I `close`the holes on the cover from the outside with ducking tape, then I put a few small pieces of wax (that was originally on the pickup) in it, heat it up (hairdryer, hot water, whatever... don´t use a lighter! :-)) and then push the pickup hard into the cover and let the wax cool down under the pressure. This makes sure that there are no gaps and the cover fits as tightly as possible.
Then a little soldering (be quick here) on the back and its done.
Works great for me.
Also, you should not worry about covers so much, they all do the same to the sound, which is like putting a thin blanket on the speaker.
With my method you can try your pickup with and without cover, whatever you like best.
I have the RY as well, Without cover it sounds more agressive, more in your face, the cover takes away just a bit of that.
I use it with cover, makes the sound more elegant.
Hope this helps!!!
rjtm
I would like to know the answer to this question too. Were they R & D'd with the covers on them?
Quote from: rjtm on April 12, 2012, 12:04:18 AM
why don't you call or email BKP and ask them, they're sure to know  :roll:
ZeroFiveFour
Quote from: monkey8911 on April 10, 2012, 01:11:21 PM
Works great for me.
Hope this helps!!!
monkey,
Thanks for the great info and video.
I really appreciate it!
Cheers,
Tom
ZeroFiveFour
Quote from: HTH AMPS on April 12, 2012, 09:36:41 PM
HTH,
That is a really good idea.  Never thought to do that to be honest. Think I'll do that. My time zone is Hawaii so I have a 13 hour time differential. I guess I will have to try some time late tonight my time.
Cheers,
Tom
