Author Topic: Unhappy with C-Pig...suggestions?  (Read 2028 times)
out_of_focus
  • Strawweight
« on: April 03, 2012, 09:08:40 PM »
Hey all, this is my first post. I got a C-Pig not too long ago based off of Ben's suggestion after I described the sound I was looking for and sent links to my band. I must say though, I am not very happy with my choice. I find the pickup to sound way too compressed, and it has too much low/low-mid to the point where it doesn't cut through the mix well at high volumes.  I have experimented with my amp EQ settings, but still haven't found a tone I really love. I am playing fast/slow heavy hardcore/punk/grind stuff on an Ibanez RGA 121 (mahogany w/ maple top, bolt on maple neck). I'm playing through a VTM120 and a Blackstar HT-100 each through their own Emperor 4x12/2x12 stack.  One of the 4x12s has G12T-75s, and the other 3 cabs have Weber 65's.
Thanks in advance!
Madsakre
Re: Unhappy with C-Pig...suggestions?
« Reply #1 on: April 03, 2012, 09:18:10 PM »
add mids. Reduce bass.
We play grind in A. Mids are maxed out, and theres a cpig in the bridge. Sounds amazing
Cattlepress
out_of_focus
  • Strawweight
« Reply #2 on: April 03, 2012, 09:26:01 PM »
Yeah, I cut the lows significantly, reduced resonance on the Blackstar, played with mids/highs/presence...you name it, and it still sounds too muddy. Hate to say it, but it sounded meaner with the stock pickup - which was too flat sounding and a bit thin.  What kind of amp are you playing through?
Madsakre
« Reply #3 on: April 03, 2012, 09:46:44 PM »
Depends. My rig is a Pod hd pro, running through a mesa poweramp into a 4x12 rectifier cab.
The other is a Engl blackmore into a marshall 1982 4x12 cab.
Cuts through like a tanto through butter
« Last Edit: April 03, 2012, 09:49:31 PM by Madsakre »
Cattlepress
ericsabbath
    • Colidium
« Reply #4 on: April 03, 2012, 10:48:22 PM »
the miracle man sounds amazing and very clear through the vtm120
Slartibartfarst42
  • Random Solution
« Reply #5 on: April 04, 2012, 12:24:58 PM »
If you want something tighter and with less bass I suppose the Miracle Man, Aftermath or Painkiller might work but I confess I didn't expect those criticisms of the C-Pig. When I talked to Tim about the possibility of a Warpig I was also worried about the amount of bass but he said the A-Pig was a very versatile pickup. Mine is a brighter guitar than yours though and I imagine that's why Ben suggested the C-Pig for you. Actually, now I think about it, how about a Nailbomb? I didn't like the A-Bomb I tried but I always maintained it would work better in mahogany. It was thick and aggressive like the Warpig, with incredible articulation but with less dominance in the bass. Scrub what I said at the start of this post; I would suggest Nailbomb.
BKP owned:
out_of_focus
  • Strawweight
« Reply #6 on: April 06, 2012, 07:16:59 PM »
Thanks for the feedback! Anyone interested in trading my C-Pig for a Nailbomb or Aftermath?
Attica!
« Reply #7 on: April 06, 2012, 07:32:42 PM »
Damn I wudda took that if I hadn't just traded mine, grrrrr. I really want a C-Pig now
